2021 Corvette: Service Bulletin: #N212330830-01: Service Update Bulletin - Navigation System Displays Incorrect GPS Location - (Jun 21, 2021)
Subject:  N212330830 Navigation System Displays Incorrect GPS Location
Models:  2021 Cadillac CT4 and CT5
2021 Chevrolet Corvette
Release Date: June 2020
Revision: 01
Revision Description:
This bulletin has been updated to include the Corvette. Please discard all precious copies of N212330830.
Attention:
This service update includes vehicles in dealer inventory and customer vehicles that return to the dealership for any reason. This bulletin will expire at the end of the involved vehicle’s New Vehicle Limited Warranty period.
Make
Model
Model Year
RPO
Description
From
To
Cadillac
CT4
2021
2021
CT5
Chevrolet
Involved vehicles are marked “open” on the Investigate Vehicle History screen in GM Global Warranty Management system. This site should always be checked to confirm vehicle involvement prior to beginning any required inspections and/or repairs.
Condition
Certain 2021 model year Cadillac CT4, CT5 and Chevrolet Corvette vehicles may have had incorrect parameters set in the One Time Programable (OTP) Chip area to initialize GPS Navigation System correctly once installed or assembled into the vehicle during manufacturing of the center stack module (CSM).
Correction
Dealers will reprogram the radio.
Dealers will replace the radio for Corvette vehicles.
Parts Information
No parts are required for this repair. – CT4 and CT5 Only
Use the VIN and the EPC to determine the correct radio to order – Corvette Only:
Quantity
Part Name
Part No.
1
Radio
85115281
1
Radio
85115282
The parts required for this program are on restriction and need to be obtained from an Electronic Service Center (ESC). Please refer to your “involved vehicles listing” before ordering parts.  These parts will be on Order Writing control and all orders placed through GMCCA will cancel.
Service Procedure (Corvette Only)
Replace the radio. Refer to Radio Replacement in SI.
Dealer Responsibility
Whenever a vehicle subject to this service update enters your vehicle inventory or is in your facility for service in the future, and the vehicle is still covered under the New Vehicle Limited Warranty, you must take the steps necessary to be sure the service update correction has been made before selling or releasing the vehicle.
All new, used, GM Certified Used, courtesy transportation vehicles, dealer shuttle vehicles, etc. in dealers’ possession and subject to this bulletin must be held and inspected/repaired per the service procedure of this bulletin before customers take possession of these vehicles.  Involved vehicles must be held and not delivered to customers, dealer-traded, released to auction, used for demonstration, or any other purpose.
All GM Certified Used vehicles currently in the dealers’ inventory within the Certified Pre-Owned Inventory System (CPOIS) will be de-certified andmust be held and remedied per the service procedure in this bulletin.  Upon submitting an accepted/paid warranty transaction in the Global Warranty Management (GWM) system, the vehicle can be re-certified for sale within the CPOIS system, or once again be used in the CTP program.
