2010 Corvette LS3 Engine Specifications
Below is a listing of general specifications for the 2010 Corvette LS3 engine.
LS3 6.2L V8 ENGINE SPECIFICATIONS
Engine type Overhead Valves (2 valves per cylinder)
Piston displacement, cu. in.(liter) 378.3 (6.20)
Bore and stroke, in.(cm.) 4.06 x 3.62 (10.31 x 9.19)
Compression ratio 10.7:1
Exhaust - single All
Horsepower 430@5900 rpm
Kilowatts(kW) 320.78@5900 rpm
Torque (lb.-ft.) 424@4600 rpm
Newton - Meters (N-m) 572.40@4600 rpm
C6 Corvette Forum
