2010 Corvette Corvette Coupe, Convertible and Z06 Specifications
Below are specifications for the 2010 Corvette Coupe, Convertible, and Z06 including engine, transmission, chassis, suspension, brakes, wheels, tires, dimensions and more.
2010-03-03
Source:  General Motors
Overview
Models:
Chevrolet Corvette Coupe, Convertible and Z06
Body styles / driveline:
two-door hatchback coupe with removable roof; rear-wheel drive (Coupe and Convertible)
two-door hatchback coupe with fixed roof; rear-wheel drive (Z06)
Construction:
composite body panels, hydroformed steel frame with aluminum and magnesium structural and chassis components (coupe);
composite and carbon-fiber body panels, hydroformed aluminum frame with aluminum and magnesium structural and chassis components (Z06)
Manufacturing location:
Bowling Green, Ky.
Engines
6.2L V-8 LS3
7.0L V-8 LS7 (Z06)
Displacement (cu in / cc):
376 / 6162
427 / 7008
Bore & stroke (in / mm):
4.06 x 3.62 / 103.25 x 92
4.125 x 4 / 104.8 x 101.6
Block material:
cast aluminum
cast aluminum
Cylinder head material:
cast aluminum
cast aluminum
Valvetrain:
overhead valve, two valves per cylinder
Fuel delivery:
SFI (sequential fuel injection)
Compression ratio:
10.7:1
11.0:1
Horsepower
(hp / kW @ rpm):
430 / 321 @ 5900* w/ std. exhaust
436 / 325 @ 5900* w/ opt. exhaust
505 / 377 @ 6300*
Torque (lb-ft / Nm @ rpm):
424 / 575 @ 4600*  w/ std. exhaust
428 / 580 @ 4600* w/ opt. exhaust
470 / 637 @ 4800*
Recommended fuel:
premium recommended not required
premium required
EPA estimated fuel economy (city / hwy):
15 / 25 (automatic)
16 / 26 (manual)
15 / 24 (manual)
Transmissions
six-speed manual;
standard and Z06
six-speed paddle-shift automatic
Application:
Std.
Opt.
Gear ratios (:1):
First:
2.66
4.03
Second:
1.78
2.36
Third:
1.30
1.53
Fourth:
1.00
1.15
Fifth:
0.74
0.85
Sixth:
0.50
0.67
Reverse:
2.90
3.06
Final drive ratio:
3.42
2.56
Chassis / Suspension
Z06
Front:
short/long arm (SLA) double wishbone, cast aluminum upper and lower control arms, transverse-mounted composite leaf spring, monotube shock absorber
Rear:
Traction control:
electronic traction control; Active Handling
Brakes
Z06
Type:
front and rear power-assisted disc with ABS
front and rear power-assisted disc with ABS with six-piston front and four-piston rear calipers, cross-drilled rotors
Rotor diameter x thickness (in / mm):
front: 12.8 x 1.26 / 325 x 32 (std.); 13.4 x 1.26 / 340 x 32 (w/ Magnetic Ride Control)
rear: 12 x 1 / 305 x 26; (std.); 13 x 1 / 330 x 26 (w/ Magnetic Ride Control)
front: 14 x 1.3 / 355 x 32
rear: 13.4 x 1 / 340 x 26
Brake swept area (sq in / mm):
front: 274 / 1768
rear: 200 / 1290
front: 309 / 1994
rear: 269 / 1735
Wheels & Tires
Wheel size:
front: 18-inch x 8.5-inch
rear: 19-inch x 10-inch
front: 18-inch x 9.5-inch
rear: 19-inch x 12-inch
Tires:
front: P245/40ZR18
rear: P285/35ZR19
front: P275/35ZR18
rear: P325/30ZR19
Z06
Wheelbase (in / mm):
105.7 / 2685
105.7 / 2685
Overall length (in / mm):
174.6 / 4435
175.6 / 4460
Overall width (in / mm):
72.6 / 1844
75.9 / 1928
Overall height (in / mm):
49 / 1244
48.7 / 1236
Curb weight (lb / kg):
3208 / 1455 (Coupe)
3221 / 1461 (Convertible)
3175 / 1440 (Z06)
Weight distribution (% front / rear):
51 / 49 (Coupe and Convertible)
50 / 50 (Z06)
Interior
Seating capacity
2
Interior volume (cu ft / L):
52 / 1475 (all models)
Headroom (in / mm):
38 / 962 (all models)
Legroom (in / mm):
43 / 1092 (all models)
Shoulder room (in / mm):
55 / 1397 (all models)
Hip room (in / mm):
54 / 1371 (all models)
Capacities
Cargo volume
(cu ft / L):
Coupe and Z06: 22 / 634
Convertible: 11 / 295 (top up); 7.5 / 212 (top down)
Fuel tank (gal / L):
18 / 68.1
Engine oil (qt / L):
5.5 / 5.2 (Coupe and Convertible)
10.5 / 9.9 (Z06)
* SAE certified.
