1998 Corvette specifications, including engine, drivetrain, dimensions, brakes, suspension, colors, wheels, performance numbers, paint codes and more.
Dimensions |
Wheelbase (in.) |
104.5 |
Track Frt/Rear (in.) |
62.0 / 62.1 |
Length (in.) |
179.7 |
Width (in.) |
73.6 |
Height (in.) |
47.7 |
Frontal Area (in.) |
NA |
Ground Clearance (in.) (minimum) |
3.7 |
Curb Weight (lbs.) |
3,245 (Coupe)
3,246 (Convertible) |
Coefficient of Drag |
0.29 (coupe) 0.32 (convert.) |
Weight Distribution |
51.5/48.5 (man. trans.) 50.8/49.2 (auto trans.) |
Coolant Capacity (qt.) |
12.0 (12.4 w/ manual trans.) |
Fuel Capacity (gal.) |
19.1 |
Oil Capacity (qt.) (w/ filter) |
6.0 |
Engine Specifications |
Type |
Overhead valve, pushrod V8, cast aluminum block and heads, 2 valves/cylinder |
Bore |
3.90 in. |
Stroke |
3.62 in. |
Displacement (liters/cid) |
5.68/346 |
Compression Ratio |
10.1:1 |
Horsepower |
345 bhp @ 5600 rpm |
Torque |
350 lb-ft @ 4400 rpm |
Redline (RPM) |
6,000 |
Induction System |
Sequential Fuel Injection |
Valvetrain |
Hydraulic roller lifters |
Brakes
Type |
4-wheel, Bosch Anti-Lock Brakes |
Front Rotors (diam. x thickness) (in.) |
11.9 x .78 (12.8 x 1.1 in. with RPO Z51) |
Rear Rotors (diam x thickness) (in.) |
Tires / Wheels |
Tire Type |
Goodyear EMT F1 High-Performance |
Front Tires |
P245/40ZR-17 |
Rear Tires |
P275/40ZR-18 |
Wheel Type |
Cast Aluminum (std.), Magnesium (opt.) |
Front Wheel Size |
17 x 8.5 |
Rear Wheel Size |
18 x 9.5 |
Transmission |
Automatic |
Manual |
Type |
4-Speed Automatic |
6-Speed Borg-Warner |
Gear Ratios |
1st |
3.06 |
2.66 |
2nd |
1.63 |
1.78 |
3rd |
1.00 |
1.30 |
4th |
0.7 |
1.00 |
5th |
NA |
0.74 |
6th |
NA |
0.50 |
Reverse |
2.29 |
2.90 |
Axle Ratio |
2.73 (3.15 opt.) |
3.42 |
Final Drive Ratio |
1.91 (2.21 opt.) |
1.71 |
Mileage |
City (mpg) |
17 |
18 |
Highway (mpg) |
25 |
28 |
Paint Codes |
RPO Code |
Color |
Valspar Code |
PPG Code |
DuPont Code |
RM Code |
SW Code |
MS Code |
Azko Code |
WA Code |
10U |
Arctic White |
W243 |
4185 |
B8949 |
19005 |
40911 |
GMA89:10 |
9567 |
11U |
Light Pewter Metallic |
N1248 |
5377 |
B9810 |
28019 |
54690 |
GMA98:11 |
382E |
13U |
Sebring Silver Metallic |
S057 |
3822 |
D8590 |
21787 |
35369 |
GMA35:13S |
9021 |
21U |
Radar Purple Metallic |
L3563 |
5386 |
B9819 |
28087 |
55292 |
GMA98:21C |
245E |
23U |
Nassau Blue Metallic |
L3182 |
5215 |
B9773 |
27001 |
54111 |
GMA97:23 |
348D |
28U |
Navy Blue Metallic |
L3325 |
5381 |
B9808 |
54695 |
GMA98:28 |
352E |
41U |
Black |
K090 |
9700 |
F02H |
13572 |
33756 |
3069 |
GMA78:19 |
8555 |
53U |
Light Carmine Red Metallic |
R2127 |
5219 |
B9723 |
27005 |
52974 |
GMA97:53 |
307D |
58U |
Aztec Gold Metallic |
B2756 |
5509 |
56639 |
GMA98:58 |
170E |
70U |
Torch Red |
R311 |
4230 |
B9008 |
20002 |
42027 |
GMA91:70 |
9075 |
87U |
Fairway Green Metallic |
G1992 |
5250 |
B9729 |
27000 |
53516 |
GMA97:87 |
309D |
95U |
Medium Purple Pearl Metallic |
L1535 |
5001 |
B9543 |
25009 |
50234 |
GMA95:95 |
111B |
