Below is a complete listing of 1979 Corvette specifications including engine, chassis, drivetrain, suspension specs and more.
Dimensions |
Wheelbase (in.) |
98.0 |
Track Frt/Rear (in) |
58.7 / 59.5 |
Length (in.) |
185.2 |
Width (in.) |
69.0 |
Height (in.) |
48 |
Frontal Area (in) |
NA |
Ground Clearance (in.) (minimum) |
4.3 in. |
Curb Weight (lbs) |
3480 |
Weight-to-power ratio (lbs:hp) |
NA |
Coefficient of Drag |
NA |
Weight Dist. F/R (%) |
47.1 / 52.9 |
Coolant Capacity (qt.) |
20.7 |
Fuel Capacity (gal.) |
24.0 |
Oil Capacity (qt.) (w/ filter) |
5.0 |
Engine Specifications |
L48 |
L82 |
Type |
Overhead valve, 350 ci, pushrod V8, 2 valves/cylinder |
Bore |
4.00 in |
4.00 in |
Stroke |
3.48 |
3.48 |
Displacement |
350 ci. |
350 ci. |
Compression Ratio |
NA |
8.9:1 |
Horsepower |
195 hp |
225 hp @ 5200 rpm |
Torque |
NA |
270 lb-ft. @ 3600 rpm |
Redline (RPM) |
NA |
NA |
Induction System |
1 x 4 bbl Rochester |
Valvetrain |
Hydraulic Lifters |
Hydraulic Lifters |
Miscellaneous |
Brakes |
Type |
4-wheel power-assist vented disk |
Front Rotors (diam x thickness) |
11.8 in. |
Rear Rotors (diam x thickness) |
11.8 in. |
Wheels and Tires |
Wheel Size |
8.0 x 15 in. |
Wheel Type |
Cast alloy |
Tire Type |
Goodyear Steel Belted Radials |
Transmission |
Automatic |
Manual |
Type |
3-Speed Automatic |
4-Speed Manual |
Gear Ratios |
1st |
2.48 |
2.64 |
2nd |
1.48 |
1.75 |
3rd |
1.00 |
1.34 |
4th |
NA |
1.00 |
Reverse |
2.08:1 |
NA |
Axle Ratio |
NA |
NA |
Final Drive Ratio |
3.55:1 |
3.70:1 |
1979 Corvette Drivetrain Specifications
