<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-roof-panel-attaching-point-adjustment-999.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1989-corvette-service-bulletin-yellowing-paint-on-or-around-headlamp-doors-white-only-164.html</guid>
										<title>1988 - 1989 Corvette: Service Bulletin:  Yellowing Paint on or Around Headlamp Doors (White Only)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1989-corvette-service-bulletin-yellowing-paint-on-or-around-headlamp-doors-white-only-164.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1985-corvette-service-bulletin-door-ajar-switch-corrosion-583.html</guid>
										<title>1984 - 1985 Corvette: Service Bulletin: Door Ajar Switch Corrosion</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1985-corvette-service-bulletin-door-ajar-switch-corrosion-583.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-paint-code-release-update-information-665.html</guid>
										<title>1984 Corvette:  Service Bulletin:  Paint Code Release Update Information</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-paint-code-release-update-information-665.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1994-1995-corvette-service-bulletin-door-glass-scratching-replace-outer-seal-in-addition-to-glass-55.html</guid>
										<title>1994 - 1995 Corvette:  Service Bulletin:  Door Glass Scratching (Replace outer seal in addition to glass)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1994-1995-corvette-service-bulletin-door-glass-scratching-replace-outer-seal-in-addition-to-glass-55.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-water-leakage-preventing-water-leaks-into-the-interior-near-side-windows-666.html</guid>
										<title>1984 - 1996 Corvette: Water Leakage: Preventing Water Leaks Into the Interior Near Side Windows</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-water-leakage-preventing-water-leaks-into-the-interior-near-side-windows-666.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-roof-panels-vin-etching-668.html</guid>
										<title>1984 - 1996 Corvette: Roof Panels - VIN Etching</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-roof-panels-vin-etching-668.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-1988-corvette-service-bulletin-roof-panel-adjustment-procedures-661.html</guid>
										<title>1986 - 1988 Corvette: Service Bulletin: Roof Panel Adjustment Procedures</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-1988-corvette-service-bulletin-roof-panel-adjustment-procedures-661.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1993-corvette-service-bulletin-right-door-glass-binds-insufficient-travel-unable-to-contact-weatherstrips-647.html</guid>
										<title>1993 Corvette: Service Bulletin: Right Door Glass Binds, Insufficient Travel, Unable to Contact Weatherstrips</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1993-corvette-service-bulletin-right-door-glass-binds-insufficient-travel-unable-to-contact-weatherstrips-647.html</link>
