<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-1957-corvette-service-news-corvette-transmission-mount-998.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-corvette-service-news-powerglide-transmission-850.html</guid>
										<title>1953 Corvette: Service News: Powerglide Transmission</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-corvette-service-news-powerglide-transmission-850.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-corvette-service-news-1959-powerglide-production-variations-1056.html</guid>
										<title>1959 Corvette Service News:  1959 Powerglide Production Variations</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-corvette-service-news-1959-powerglide-production-variations-1056.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1962-1963-corvette-service-bulletin-governor-rattle-after-reverse-operation-967.html</guid>
										<title>1962 - 1963 Corvette:  Service Bulletin:  Governor Rattle After Reverse Operation</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1962-1963-corvette-service-bulletin-governor-rattle-after-reverse-operation-967.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1961-corvette-service-bulletin-3-speed-transmission-extension-bushing-1009.html</guid>
										<title>1961 Corvette:  Service Bulletin:  3-Speed Transmission Extension Bushing</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1961-corvette-service-bulletin-3-speed-transmission-extension-bushing-1009.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-rear-engine-mountings-1955-passenger-6-8-cylinder-with-powerglide-772.html</guid>
										<title>1955 Corvette: Service Bulletin: Rear Engine Mountings 1955 Passenger 6 &amp; 8 Cylinder With Powerglide</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-rear-engine-mountings-1955-passenger-6-8-cylinder-with-powerglide-772.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-foreign-material-in-clutch-housings-secondary-road-operation-790.html</guid>
										<title>1955 Corvette: Service Bulletin: Foreign Material in Clutch Housings, Secondary Road Operation</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-foreign-material-in-clutch-housings-secondary-road-operation-790.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1958-corvette-service-bulletin-speedometer-driven-gear-870.html</guid>
										<title>1958 Corvette: Service Bulletin: Speedometer Driven Gear</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1958-corvette-service-bulletin-speedometer-driven-gear-870.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-1958-corvette-service-news-corvette-4-speed-transmission-harsh-shift-into-third-speed-789.html</guid>
										<title>1957 - 1958 Corvette: Service News: Corvette 4-Speed Transmission - Harsh Shift Into Third Speed</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-1958-corvette-service-news-corvette-4-speed-transmission-harsh-shift-into-third-speed-789.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-corvette-service-bulletin-powerglide-transmission-slippage-and-chatter-in-automatic-low-and-drive-range-81.html</guid>
										<title>1953 Corvette:  Service Bulletin:  Powerglide Transmission Slippage and Chatter in Automatic Low and Drive Range</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-corvette-service-bulletin-powerglide-transmission-slippage-and-chatter-in-automatic-low-and-drive-range-81.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-corvette-service-bulletin-clutch-disc-springs-periodic-vibration-991.html</guid>
										<title>1956 Corvette Service Bulletin:  Clutch Disc - Springs - Periodic Vibration</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-corvette-service-bulletin-clutch-disc-springs-periodic-vibration-991.html</link>
