<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1985-corvette-service-bulletin-paint-repair-without-repainting-996.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-roof-panel-attaching-point-adjustment-999.html</guid>
										<title>1984 Corvette:  Service Bulletin:  Roof Panel Attaching Point Adjustment</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-roof-panel-attaching-point-adjustment-999.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1994-1995-corvette-service-bulletin-door-glass-scratching-replace-outer-seal-in-addition-to-glass-55.html</guid>
										<title>1994 - 1995 Corvette:  Service Bulletin:  Door Glass Scratching (Replace outer seal in addition to glass)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1994-1995-corvette-service-bulletin-door-glass-scratching-replace-outer-seal-in-addition-to-glass-55.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1985-1991-corvette-service-bulletin-paint-etching-staining-and-permanent-water-spotting-662.html</guid>
										<title>1985 - 1991 Corvette: Service Bulletin: Paint Etching/Staining and Permanent Water Spotting</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1985-1991-corvette-service-bulletin-paint-etching-staining-and-permanent-water-spotting-662.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-broken-window-regulator-tapes-983.html</guid>
										<title>1984 Corvette:  Service Bulletin:  Broken Window Regulator Tapes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-broken-window-regulator-tapes-983.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-competition-yellow-paint-comments-about-color-changes-654.html</guid>
										<title>1990 Corvette: Service Bulletin: Competition Yellow Paint Comments About Color Changes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-service-bulletin-competition-yellow-paint-comments-about-color-changes-654.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1993-corvette-service-bulletin-right-door-glass-binds-insufficient-travel-unable-to-contact-weatherstrips-647.html</guid>
										<title>1993 Corvette: Service Bulletin: Right Door Glass Binds, Insufficient Travel, Unable to Contact Weatherstrips</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1993-corvette-service-bulletin-right-door-glass-binds-insufficient-travel-unable-to-contact-weatherstrips-647.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-administrative-message-1990-corvette-competition-yellow-paint-photosensitivity-655.html</guid>
										<title>1990 Corvette: Administrative Message: 1990 Corvette, Competition Yellow Paint Photosensitivity</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-administrative-message-1990-corvette-competition-yellow-paint-photosensitivity-655.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-corvette-service-bulletin-potential-paint-peeling-on-front-fascias-652.html</guid>
										<title>1991 Corvette: Service Bulletin: Potential Paint Peeling on Front Fascias</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-corvette-service-bulletin-potential-paint-peeling-on-front-fascias-652.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1986-corvette-service-bulletin-window-regulators-replacement-181.html</guid>
										<title>1984 - 1986 Corvette: Service Bulletin: Window Regulators - Replacement</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1986-corvette-service-bulletin-window-regulators-replacement-181.html</link>
