<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1954-corvette-service-bulletin-connecting-rods-988.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-1956-corvette-service-bulletin-inlet-manifold-oil-guards-1254.html</guid>
										<title>1955 - 1956 Corvette:  Service Bulletin:  Inlet Manifold Oil Guards</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-1956-corvette-service-bulletin-inlet-manifold-oil-guards-1254.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-1962-corvette-rochester-fuel-injection-part-numbers-1178.html</guid>
										<title>1957 - 1962 Corvette:  Rochester Fuel Injection Part Numbers</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-1962-corvette-rochester-fuel-injection-part-numbers-1178.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-corvette-chevrolet-technical-test-report-fuel-economy-fuel-injection-vs-carburetion-1183.html</guid>
										<title>1957 Corvette:  Chevrolet Technical Test Report:  Fuel Economy - Fuel Injection vs. Carburetion</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-corvette-chevrolet-technical-test-report-fuel-economy-fuel-injection-vs-carburetion-1183.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-new-gasoline-gauge-148.html</guid>
										<title>1955 Corvette:  Service Bulletin:  New Gasoline Gauge</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-new-gasoline-gauge-148.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1960-1961-corvette-service-bulletin-corvette-aluminum-radiator-replacement-1236.html</guid>
										<title>1960 - 1961 Corvette:  Service Bulletin:  Corvette Aluminum Radiator Replacement</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1960-1961-corvette-service-bulletin-corvette-aluminum-radiator-replacement-1236.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-oil-pump-suction-pipe-174.html</guid>
										<title>1955 Corvette:  Service Bulletin: Oil Pump Suction Pipe</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-oil-pump-suction-pipe-174.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-1963-corvette-service-news-new-fuel-injection-service-kits-available-927.html</guid>
										<title>1957 - 1963 Corvette:  Service News:  New Fuel Injection Service Kits Available</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-1963-corvette-service-news-new-fuel-injection-service-kits-available-927.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-1961-corvette-service-news-fuel-injection-change-901.html</guid>
										<title>1959 - 1961 Corvette:  Service News:  Fuel Injection Change</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-1961-corvette-service-news-fuel-injection-change-901.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1954-corvette-service-bulletin-production-and-service-1954-piston-rings-1060.html</guid>
										<title>1954 Corvette:  Service Bulletin:  Production and Service 1954 Piston Rings</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1954-corvette-service-bulletin-production-and-service-1954-piston-rings-1060.html</link>
