<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1980-corvette-service-bulletin-rear-wheel-spindle-yoke-snapping-noise-985.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-1972-corvette-frame-specifications-256.html</guid>
										<title>1969 - 1972 Corvette: Frame Specifications</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-1972-corvette-frame-specifications-256.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1982-corvette-chevrolet-service-news-rear-spring-removal-service-update-1237.html</guid>
										<title>1963 - 1982 Corvette:  Chevrolet Service News:  Rear Spring Removal Service Update</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1982-corvette-chevrolet-service-news-rear-spring-removal-service-update-1237.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1978-1982-corvette-frame-specifications-255.html</guid>
										<title>1978 - 1982 Corvette: Frame Specifications</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1978-1982-corvette-frame-specifications-255.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1980-1982-corvette-service-news-differential-side-bearing-removal-936.html</guid>
										<title>1980 - 1982 Corvette:  Service News:  Differential Side Bearing Removal</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1980-1982-corvette-service-news-differential-side-bearing-removal-936.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1974-corvette-service-news-corvette-rear-wheel-end-play-adjustment-and-inner-bearing-lubrication-747.html</guid>
										<title>1963 - 1974 Corvette: Service News: Corvette Rear Wheel End Play Adjustment and Inner Bearing Lubrication</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1974-corvette-service-news-corvette-rear-wheel-end-play-adjustment-and-inner-bearing-lubrication-747.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-service-news-steering-knuckle-and-ball-stud-servicing-all-passenger-car-and-truck-models-824.html</guid>
										<title>1973 + Corvette: Service News: Steering Knuckle and Ball Stud Servicing - All Passenger Car and Truck Models</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-service-news-steering-knuckle-and-ball-stud-servicing-all-passenger-car-and-truck-models-824.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1972-corvette-service-news-positraction-chatter-1972-passenger-cars-and-10-series-trucks-825.html</guid>
										<title>1972 Corvette: Service News: Positraction Chatter - 1972 Passenger Cars and 10 Series Trucks</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1972-corvette-service-news-positraction-chatter-1972-passenger-cars-and-10-series-trucks-825.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1978-1979-corvette-service-news-access-to-right-upper-control-arm-attaching-bolt-706.html</guid>
										<title>1978 - 1979 Corvette: Service News: Access to Right Upper Control Arm Attaching Bolt</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1978-1979-corvette-service-news-access-to-right-upper-control-arm-attaching-bolt-706.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1970-corvette-service-bulletin-positraction-chatter-709.html</guid>
										<title>1970+ Corvette: Service Bulletin: Positraction Chatter</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1970-corvette-service-bulletin-positraction-chatter-709.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-l88-esl-bulletin-front-end-roll-during-hard-cornering-143.html</guid>
										<title>1968 Corvette L88:  ESL Bulletin: Front End Roll During Hard Cornering</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-l88-esl-bulletin-front-end-roll-during-hard-cornering-143.html</link>
