<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2008-corvette-gm-techlink-trip-odometer-operation-98.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2008-corvette-gm-techlink-article-fob-conditions-104.html</guid>
										<title>2005 - 2008 Corvette: GM TechLink Article: Fob Conditions</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2008-corvette-gm-techlink-article-fob-conditions-104.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-canadian-corvettes-only-recall-04096-incorrect-air-bag-off-indicator-assembly-348.html</guid>
										<title>2005 (Canadian Corvettes Only): Recall 04096: Incorrect Air Bag Off Indicator Assembly</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-canadian-corvettes-only-recall-04096-incorrect-air-bag-off-indicator-assembly-348.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2008-service-bulletin-stabilitrak-active-handling-light-on-service-stabilitrak-active-handling-message-on-dic-152.html</guid>
										<title>2005 - 2008: Service Bulletin:  Stabilitrak/Active Handling Light On, Service Stabilitrak/Active Handling Message on DIC</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-electrical-schematic-cooling-fans-209.html</guid>
										<title>2006 Corvette: Electrical Schematic: Cooling Fans</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-electrical-schematic-cooling-fans-209.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-electrical-schematic-satellite-radio-circuit-system-266.html</guid>
										<title>2006 Corvette: Electrical Schematic: Satellite Radio Circuit System</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-electrical-schematic-satellite-radio-circuit-system-266.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-service-bulletin-various-radio-cd-player-concerns-replace-radio-339.html</guid>
										<title>2005 Corvette: Service Bulletin: Various Radio/CD Player Concerns (Replace Radio)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-service-bulletin-various-radio-cd-player-concerns-replace-radio-339.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2008-corvette-gm-techlink-cd-player-condition-110.html</guid>
										<title>2008 Corvette: GM TechLink: CD Player Condition</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2008-corvette-gm-techlink-cd-player-condition-110.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-service-bulletin-language-change-for-onstar-system-u-s-only-197.html</guid>
										<title>2006 Corvette: Service Bulletin: Language Change for OnStar System (U.S. Only)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-service-bulletin-language-change-for-onstar-system-u-s-only-197.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-electrical-schematic-power-distribution-260.html</guid>
										<title>2006 Corvette:  Electrical Schematic:  Power Distribution</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-electrical-schematic-power-distribution-260.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2006-corvette-service-bulletin-diagnostic-trouble-code-dtc-c0710-steering-wheel-position-sensor-swps-signal-service-stability-system-message-on-driver-information-center-dic-216.html</guid>
										<title>2005 - 2006 Corvette: Service Bulletin: Diagnostic Trouble Code (DTC) C0710 Steering Wheel Position Sensor (SWPS) Signal, Service Stability System Message on Driver Information Center (DIC)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-2006-corvette-service-bulletin-diagnostic-trouble-code-dtc-c0710-steering-wheel-position-sensor-swps-signal-service-stability-system-message-on-driver-information-center-dic-216.html</link>
