<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-corvette-service-bulletin-spark-plug-fouling-idle-adjustment-975.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-1956-corvette-service-bulletin-inlet-manifold-oil-guards-1254.html</guid>
										<title>1955 - 1956 Corvette:  Service Bulletin:  Inlet Manifold Oil Guards</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-1956-corvette-service-bulletin-inlet-manifold-oil-guards-1254.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-corvette-service-bulletin-spark-plug-replacement-179.html</guid>
										<title>1957 Corvette: Service Bulletin: Spark Plug Replacement</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-corvette-service-bulletin-spark-plug-replacement-179.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-new-gasoline-gauge-148.html</guid>
										<title>1955 Corvette:  Service Bulletin:  New Gasoline Gauge</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-new-gasoline-gauge-148.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1960-corvette-service-bulletin-correction-for-erratic-tachometer-operation-952.html</guid>
										<title>1960 Corvette:  Service Bulletin:  Correction for Erratic Tachometer Operation</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1960-corvette-service-bulletin-correction-for-erratic-tachometer-operation-952.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-service-news-vent-the-window-regulator-motor-993.html</guid>
										<title>1965 Corvette:  Service News:  Vent the Window Regulator Motor</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-service-news-vent-the-window-regulator-motor-993.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-specification-sheets-for-the-adjustment-and-parts-sizes-for-the-four-barrel-carburetor-1141.html</guid>
										<title>1955 Corvette:  Service Bulletin:  Specification Sheets for the Adjustment and Parts Sizes for the Four Barrel Carburetor</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-specification-sheets-for-the-adjustment-and-parts-sizes-for-the-four-barrel-carburetor-1141.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-zone-letter-directional-signal-failures-1033.html</guid>
										<title>1955 Corvette:  Zone Letter:  Directional Signal Failures</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-zone-letter-directional-signal-failures-1033.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-new-oil-level-gauge-146.html</guid>
										<title>1955 Corvette:  Service Bulletin:  New Oil Level Gauge</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-new-oil-level-gauge-146.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-1961-corvette-service-news-fuel-injection-change-901.html</guid>
										<title>1959 - 1961 Corvette:  Service News:  Fuel Injection Change</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-1961-corvette-service-news-fuel-injection-change-901.html</link>
