<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-corvette-service-bulletin-choke-problems-973.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1977-1982-corvette-service-bulletin-care-and-maintenance-of-tape-players-and-cartridges-1116.html</guid>
										<title>1977 - 1982 Corvette:  Service Bulletin:  Care and Maintenance of Tape Players and Cartridges</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1977-1982-corvette-service-bulletin-care-and-maintenance-of-tape-players-and-cartridges-1116.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-holley-model-2300-carburetor-revisions-1231.html</guid>
										<title>1968 Corvette:  Service Bulletin:  Holley Model 2300 Carburetor Revisions</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-holley-model-2300-carburetor-revisions-1231.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-engineering-service-letter-engine-harness-replacement-corvette-transistor-ignition-914.html</guid>
										<title>1968 Corvette:  Engineering Service Letter:  Engine Harness Replacement Corvette Transistor Ignition</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-engineering-service-letter-engine-harness-replacement-corvette-transistor-ignition-914.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-1991-corvette-service-bulletin-parasitic-drain-on-battery-ammeter-connecting-procedure-689.html</guid>
										<title>1982 - 1991 Corvette: Service Bulletin: Parasitic Drain on Battery Ammeter Connecting Procedure</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1979-corvette-service-bulletin-halogen-sealed-beams-172.html</guid>
										<title>1979 Corvette: Service Bulletin: Halogen Sealed Beams</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1979-corvette-service-bulletin-halogen-sealed-beams-172.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-heat-damage-to-engine-wiring-harness-943.html</guid>
										<title>1968 Corvette:  Service Bulletin:  Heat Damage to Engine Wiring Harness</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-heat-damage-to-engine-wiring-harness-943.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-corvette-service-news-battery-with-side-mounted-terminals-920.html</guid>
										<title>1969 Corvette:  Service News:  Battery with Side-Mounted Terminals</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-corvette-service-news-battery-with-side-mounted-terminals-920.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-1970-corvette-service-bulletin-voltage-regulator-failures-in-the-1970-integrated-delcotrons-865.html</guid>
										<title>1969 - 1970 Corvette: Service Bulletin: Voltage Regulator Failures in the 1970 Integrated Delcotrons</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-1970-corvette-service-bulletin-voltage-regulator-failures-in-the-1970-integrated-delcotrons-865.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1979-corvette-service-news-corvette-auxiliary-cooling-fan-wiring-revision-897.html</guid>
										<title>1979 Corvette:  Service News:  Corvette Auxiliary Cooling Fan Wiring Revision</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1979-corvette-service-news-corvette-auxiliary-cooling-fan-wiring-revision-897.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-1972-corvette-service-bulletin-moisture-entering-pulse-amplifier-transistor-ignition-systems-932.html</guid>
										<title>1965 - 1972 Corvette:  Service Bulletin:  Moisture Entering Pulse Amplifier - Transistor Ignition Systems</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-1972-corvette-service-bulletin-moisture-entering-pulse-amplifier-transistor-ignition-systems-932.html</link>
