<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2002-corvette-gm-techlink-hydraulic-clutch-fluid-discoloration-97.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2000-2006-corvette-service-bulletin-diagnostic-information-on-diagnostic-trouble-code-dtc-p0894-and-p1870-215.html</guid>
										<title>2000 - 2006 Corvette: Service Bulletin: Diagnostic Information on Diagnostic Trouble Code (DTC) P0894 and P1870</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2000-2006-corvette-service-bulletin-diagnostic-information-on-diagnostic-trouble-code-dtc-p0894-and-p1870-215.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2003-corvette-gm-techlink-transmission-stuck-in-gear-435.html</guid>
										<title>1997 - 2003 Corvette: GM TechLink: Transmission Stuck in Gear</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2003-corvette-gm-techlink-transmission-stuck-in-gear-435.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2005-corvette-gm-techlink-no-crank-prndl-inoperative-342.html</guid>
										<title>2005 Corvette: GM TechLink: No Crank, PRNDL Inoperative</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-2003-corvette-service-bulletin-info-diagnosis-of-cracked-or-broken-transmission-case-439.html</guid>
										<title>1990 - 2003 Corvette: Service Bulletin: Info - Diagnosis of Cracked or Broken Transmission Case</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-2003-corvette-service-bulletin-info-diagnosis-of-cracked-or-broken-transmission-case-439.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1998-corvette-service-news-automatic-transmission-operation-868.html</guid>
										<title>1997 - 1998 Corvette:  Service News:  Automatic Transmission Operation</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1998-corvette-service-news-automatic-transmission-operation-868.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-1999-corvette-service-bulletin-tech-service-engine-soon-ses-light-illuminates-repl-switch-assy-434.html</guid>
										<title>1998 - 1999 Corvette: Service Bulletin: Tech - Service Engine Soon (SES) Light Illuminates (Repl Switch Assy)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-1999-corvette-service-bulletin-tech-service-engine-soon-ses-light-illuminates-repl-switch-assy-434.html</link>
