<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-bulletin-3-and-4-speed-transmission-clutch-gear-bearing-retainer-failure-963.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-zone-letter-propeller-shaft-balancing-46.html</guid>
										<title>1963 Corvette: Zone Letter: Propeller Shaft Balancing</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-zone-letter-propeller-shaft-balancing-46.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-reliability-data-center-letter-poor-release-and-high-pedal-effort-1966-327-cid-corvette-engines-1100.html</guid>
										<title>1966 Corvette:  Reliability Data Center Letter:  Poor Release and High Pedal Effort - 1966 327 CID Corvette Engines</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-reliability-data-center-letter-poor-release-and-high-pedal-effort-1966-327-cid-corvette-engines-1100.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-bulletin-improved-vacuum-modulator-957.html</guid>
										<title>1963 Corvette:  Service Bulletin:  Improved Vacuum Modulator</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-bulletin-improved-vacuum-modulator-957.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-bulletin-gear-block-out-and-high-shifting-effort-742.html</guid>
										<title>1963 Corvette: Service Bulletin: Gear Block-Out and High Shifting Effort</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-bulletin-gear-block-out-and-high-shifting-effort-742.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-bulletin-powerglide-transmission-governor-operational-check-958.html</guid>
										<title>1963 Corvette:  Service Bulletin:  Powerglide Transmission Governor Operational Check</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-bulletin-powerglide-transmission-governor-operational-check-958.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1967-corvette-service-news-periodically-lubricate-manual-transmission-shift-mechanism-sn-c-30-876.html</guid>
										<title>1963 - 1967 Corvette: Service News: Periodically Lubricate Manual Transmission Shift Mechanism (SN-C-30)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1967-corvette-service-news-periodically-lubricate-manual-transmission-shift-mechanism-sn-c-30-876.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-1966-corvette-service-bulletin-reverse-lockout-mechanism-revised-1195.html</guid>
										<title>1964 - 1966 Corvette:  Service Bulletin:  Reverse Lockout Mechanism Revised</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-1966-corvette-service-bulletin-reverse-lockout-mechanism-revised-1195.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-1966-corvette-chevrolet-engineering-bulletin-powerglide-transmission-control-rod-adjustment-739.html</guid>
										<title>1965 - 1966 Corvette: Chevrolet Engineering Bulletin: Powerglide Transmission Control Rod Adjustment</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-1966-corvette-chevrolet-engineering-bulletin-powerglide-transmission-control-rod-adjustment-739.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-corvette-service-bulletin-1964-clutch-interim-changes-1252.html</guid>
										<title>1964 Corvette:  Service Bulletin:  1964 Clutch Interim Changes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-corvette-service-bulletin-1964-clutch-interim-changes-1252.html</link>
