<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-service-news-rough-idle-or-vibration-960.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2017-corvette-z06-service-bulletin-pip5395b-ticking-rattle-or-buzz-noise-heard-the-best-in-the-passenger-compartment-mar-20-2017-1338.html</guid>
										<title>2015 - 2017 Corvette Z06: Service Bulletin: #PIP5395B: Ticking Rattle Or Buzz Noise Heard The Best In The Passenger Compartment - (Mar 20, 2017)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2017-corvette-z06-service-bulletin-pip5395b-ticking-rattle-or-buzz-noise-heard-the-best-in-the-passenger-compartment-mar-20-2017-1338.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-gm-techlink-oil-leak-after-the-harmonic-balancer-is-removed-1065.html</guid>
										<title>2014 Corvette:  GM TechLink:  Oil Leak after the Harmonic Balancer is Removed</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-gm-techlink-oil-leak-after-the-harmonic-balancer-is-removed-1065.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2018-corvette-z06-service-bulletin-special-coverage-adjustment-n202302720-on-track-performance-engine-overheating-1478.html</guid>
										<title>2015 - 2018 Corvette Z06: Service Bulletin: Special Coverage Adjustment N202302720 On Track Performance Engine Overheating</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2018-corvette-z06-service-bulletin-special-coverage-adjustment-n202302720-on-track-performance-engine-overheating-1478.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-gm-techlink-article-extended-cold-crank-with-direct-injected-engines-8.html</guid>
										<title>2014 - 2015 Corvette: GM TechLink Article: Extended Cold Crank with Direct Injected Engines</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-gm-techlink-article-extended-cold-crank-with-direct-injected-engines-8.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-gm-techlink-6-2l-engine-bell-housing-rattle-1012.html</guid>
										<title>2014 - 2015 Corvette:  GM TechLink:  6.2L Engine Bell Housing Rattle</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-gm-techlink-6-2l-engine-bell-housing-rattle-1012.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-2017-corvette-service-bulletin-reminder-2016-2017my-z51-grand-sport-and-z06-corvettes-required-maintenance-chevrolet-complete-care-1355.html</guid>
										<title>2016 - 2017 Corvette:  Service Bulletin: Reminder - 2016/2017MY - Z51, Grand Sport and Z06 Corvettes - Required Maintenance/Chevrolet Complete Care</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-2017-corvette-service-bulletin-reminder-2016-2017my-z51-grand-sport-and-z06-corvettes-required-maintenance-chevrolet-complete-care-1355.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2018-corvette-service-bulletin-pip5248d-stalling-shudder-and-or-hard-shifting-into-1st-gear-or-reverse-vibration-on-launch-1377.html</guid>
										<title>2014 - 2018 Corvette:  Service Bulletin:  #PIP5248D: Stalling Shudder And/or Hard   shifting Into 1st Gear Or Reverse Vibration On launch</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2018-corvette-service-bulletin-pip5248d-stalling-shudder-and-or-hard-shifting-into-1st-gear-or-reverse-vibration-on-launch-1377.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2016-corvette-z06-gm-techlink-track-engine-temperature-on-track-ready-corvettes-1232.html</guid>
										<title>2015 - 2016 Corvette Z06:  GM TechLink:  Track Engine Temperature on Track-Ready Corvettes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2016-corvette-z06-gm-techlink-track-engine-temperature-on-track-ready-corvettes-1232.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2012-2017-corvette-service-bulletin-17-na-157-information-on-spin-on-oil-filter-replacement-for-gas-engines-designed-with-new-oil-pump-control-systems-1363.html</guid>
										<title>2012 - 2017 Corvette: Service Bulletin: #17-NA-157: Information on Spin-On Oil Filter Replacement for Gas Engines Designed with New Oil Pump Control Systems</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2012-2017-corvette-service-bulletin-17-na-157-information-on-spin-on-oil-filter-replacement-for-gas-engines-designed-with-new-oil-pump-control-systems-1363.html</link>
