<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-bulletin-transmission-shift-lever-vibration-959.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-zone-letter-propeller-shaft-balancing-46.html</guid>
										<title>1963 Corvette: Zone Letter: Propeller Shaft Balancing</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-zone-letter-propeller-shaft-balancing-46.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-chevrolet-engineering-service-letter-telescoping-steering-wheel-horn-button-cap-liner-no-42-909.html</guid>
										<title>1965 Corvette: Chevrolet Engineering Service Letter:  Telescoping Steering Wheel Horn button Cap Liner - (No. 42)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-chevrolet-engineering-service-letter-telescoping-steering-wheel-horn-button-cap-liner-no-42-909.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-service-bulletin-turn-signal-switch-failure-to-cancel-1209.html</guid>
										<title>1965 Corvette:  Service Bulletin:  Turn Signal Switch - Failure to Cancel</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-service-bulletin-turn-signal-switch-failure-to-cancel-1209.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-1966-corvette-service-bulletin-gear-shift-control-assembly-buzz-1103.html</guid>
										<title>1964 - 1966 Corvette:  Service Bulletin:  Gear Shift Control Assembly Buzz</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-1966-corvette-service-bulletin-gear-shift-control-assembly-buzz-1103.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-1966-corvette-service-bulletin-reverse-lockout-mechanism-revised-1195.html</guid>
										<title>1964 - 1966 Corvette:  Service Bulletin:  Reverse Lockout Mechanism Revised</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-1966-corvette-service-bulletin-reverse-lockout-mechanism-revised-1195.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-bulletin-powerglide-transmission-governor-operational-check-958.html</guid>
										<title>1963 Corvette:  Service Bulletin:  Powerglide Transmission Governor Operational Check</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-bulletin-powerglide-transmission-governor-operational-check-958.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-corvette-production-information-genuine-leather-seats-1148.html</guid>
										<title>1964 Corvette:  Production Information:  Genuine Leather Seats</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-corvette-production-information-genuine-leather-seats-1148.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-corvette-service-bulletin-1964-clutch-interim-changes-1252.html</guid>
										<title>1964 Corvette:  Service Bulletin:  1964 Clutch Interim Changes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-corvette-service-bulletin-1964-clutch-interim-changes-1252.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-corvette-service-news-1964-powerglide-removal-and-reinstallation-740.html</guid>
										<title>1964 Corvette: Service News: 1964 Powerglide Removal and Reinstallation</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-corvette-service-news-1964-powerglide-removal-and-reinstallation-740.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-bulletin-improved-vacuum-modulator-957.html</guid>
										<title>1963 Corvette:  Service Bulletin:  Improved Vacuum Modulator</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-service-bulletin-improved-vacuum-modulator-957.html</link>
