<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-1960-corvette-service-bulletin-calibration-revised-to-correct-lean-condition-at-wide-open-throttle-955.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-1956-corvette-service-bulletin-oil-level-gauge-accuracy-774.html</guid>
										<title>1955 - 1956 Corvette: Service Bulletin: Oil Level Gauge - Accuracy</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-1956-corvette-service-bulletin-oil-level-gauge-accuracy-774.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1954-corvette-service-bulletin-identification-1954-camshafts-distributor-gears-camshaft-gears-all-valve-lifters-979.html</guid>
										<title>1953 - 1954 Corvette:  Service Bulletin:  Identification - 1954 Camshafts - Distributor Gears - Camshaft Gears - All Valve Lifters</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1954-corvette-service-bulletin-identification-1954-camshafts-distributor-gears-camshaft-gears-all-valve-lifters-979.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-1962-corvette-intake-manifold-casting-numbers-and-date-codes-1179.html</guid>
										<title>1956 - 1962 Corvette:  Intake Manifold Casting Numbers and Date Codes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-1962-corvette-intake-manifold-casting-numbers-and-date-codes-1179.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-corvette-service-bulletin-board-parts-mart-magazine-tune-up-specifications-947.html</guid>
										<title>1959 Corvette:  Service Bulletin Board - Parts Mart Magazine - Tune-Up Specifications</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-corvette-service-bulletin-board-parts-mart-magazine-tune-up-specifications-947.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-new-gasoline-gauge-148.html</guid>
										<title>1955 Corvette:  Service Bulletin:  New Gasoline Gauge</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-new-gasoline-gauge-148.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-1965-corvette-fuel-injection-specifications-1140.html</guid>
										<title>1957 - 1965 Corvette:  Fuel Injection Specifications</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1961-corvette-service-bulletin-hydraulic-lifter-usage-and-adjustment-761.html</guid>
										<title>1961 Corvette: Service Bulletin: Hydraulic Lifter Usage and Adjustment</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1961-corvette-service-bulletin-hydraulic-lifter-usage-and-adjustment-761.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-corvette-service-bulletin-temperature-gauge-erratic-during-normalizing-period-902.html</guid>
										<title>1956 Corvette:  Service Bulletin:  Temperature Gauge Erratic During Normalizing Period</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-corvette-service-bulletin-temperature-gauge-erratic-during-normalizing-period-902.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-oil-level-gauge-dipsticks-987.html</guid>
										<title>1955 Corvette:  Service Bulletin:  Oil Level Gauge Dipsticks</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-oil-level-gauge-dipsticks-987.html</link>
