<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-1967-corvette-service-bulletin-crankshaft-to-water-pump-drive-belt-failure-950.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-engineering-service-letter-1965-corvette-350-h-p-factory-a-c-operating-temperatures-44.html</guid>
										<title>1965 Corvette: Engineering Service Letter: 1965 Corvette 350 H.P. Factory A/C Operating Temperatures</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-engineering-service-letter-1965-corvette-350-h-p-factory-a-c-operating-temperatures-44.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1964-corvette-parts-mart-pistons-with-pins-piston-ring-specifications-1034.html</guid>
										<title>1953 - 1964 Corvette:  Parts Mart:  Pistons with Pins - Piston Ring Specifications</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1964-corvette-parts-mart-pistons-with-pins-piston-ring-specifications-1034.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1971-corvette-service-bulletin-gasoline-additive-for-preventing-exhaust-valve-recession-995.html</guid>
										<title>1953 - 1971 Corvette:  Service Bulletin:  Gasoline Additive for Preventing Exhaust Valve Recession</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1971-corvette-service-bulletin-gasoline-additive-for-preventing-exhaust-valve-recession-995.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-engineering-service-letter-dying-on-quick-right-turns-732.html</guid>
										<title>1965 Corvette: Engineering Service Letter: Dying on Quick Right Turns</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-corvette-engineering-service-letter-dying-on-quick-right-turns-732.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-corvette-service-news-servicing-1964-corvette-fuel-injection-units-47.html</guid>
										<title>1964 Corvette: Service News: Servicing 1964 Corvette Fuel Injection Units</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-corvette-service-news-servicing-1964-corvette-fuel-injection-units-47.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-engineering-service-letter-corvette-427-mark-iv-engine-surge-no-358-t-i-1017.html</guid>
										<title>1966 Corvette:  Engineering Service Letter:  Corvette 427 Mark IV Engine Surge (No. 358-T.I.)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-engineering-service-letter-corvette-427-mark-iv-engine-surge-no-358-t-i-1017.html</link>
