<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-corvette-service-bulletin-board-parts-mart-magazine-tune-up-specifications-947.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-1956-corvette-service-bulletin-inlet-manifold-oil-guards-1254.html</guid>
										<title>1955 - 1956 Corvette:  Service Bulletin:  Inlet Manifold Oil Guards</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-1956-corvette-service-bulletin-inlet-manifold-oil-guards-1254.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-corvette-service-bulletin-spark-plug-fouling-idle-adjustment-975.html</guid>
										<title>1956 Corvette:  Service Bulletin:  Spark Plug Fouling - Idle Adjustment</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-corvette-service-bulletin-spark-plug-fouling-idle-adjustment-975.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1961-corvette-service-bulletin-corvette-fuel-spillage-gas-tank-filler-cap-96.html</guid>
										<title>1961 Corvette: Service Bulletin: Corvette Fuel Spillage - Gas Tank Filler Cap</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1961-corvette-service-bulletin-corvette-fuel-spillage-gas-tank-filler-cap-96.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1959-corvette-connecting-rod-bearing-part-numbers-776.html</guid>
										<title>1953 - 1959 Corvette: Connecting Rod Bearing Part Numbers</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1959-corvette-connecting-rod-bearing-part-numbers-776.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1958-corvette-service-news-engine-oil-dipstick-identification-765.html</guid>
										<title>1958 Corvette: Service News: Engine Oil Dipstick Identification</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1958-corvette-service-news-engine-oil-dipstick-identification-765.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-corvette-service-news-fuel-injection-pump-drive-shaft-installation-177.html</guid>
										<title>1957 Corvette: Service News: Fuel Injection Pump Drive Shaft Installation</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-corvette-service-news-fuel-injection-pump-drive-shaft-installation-177.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-corvette-service-bulletin-automatic-choke-piston-inoperative-due-to-carbon-deposits-768.html</guid>
										<title>1957 Corvette: Service Bulletin: Automatic Choke Piston Inoperative Due to Carbon Deposits</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-corvette-service-bulletin-automatic-choke-piston-inoperative-due-to-carbon-deposits-768.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1960-corvette-service-update-tachometer-erratic-operation-145.html</guid>
										<title>1960 Corvette:  Service Update:  Tachometer Erratic Operation</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1960-corvette-service-update-tachometer-erratic-operation-145.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-corvette-service-bulletin-crankcase-breather-assembly-cap-974.html</guid>
										<title>1956 Corvette:  Service Bulletin:  Crankcase Breather Assembly (Cap)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-corvette-service-bulletin-crankcase-breather-assembly-cap-974.html</link>
