<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-united-delco-bulletin-universal-horns-946.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-passenger-car-product-bulletin-new-corvette-anti-theft-warning-system-1235.html</guid>
										<title>1968 Corvette:  Passenger Car Product Bulletin:  New Corvette Anti-Theft Warning System</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-passenger-car-product-bulletin-new-corvette-anti-theft-warning-system-1235.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-corvette-service-bulletin-spark-plug-fouling-driveability-improvements-674.html</guid>
										<title>1982 Corvette: Service Bulletin: Spark Plug Fouling/Driveability Improvements</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-corvette-service-bulletin-spark-plug-fouling-driveability-improvements-674.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1981-corvette-service-bulletin-vehicle-speed-sensor-servicing-677.html</guid>
										<title>1981 Corvette: Service Bulletin: Vehicle Speed Sensor Servicing</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-1991-corvette-service-bulletin-damaged-ecm-pcm-mis-diagnosis-due-to-incorrect-tap-testing-procedures-690.html</guid>
										<title>1982 - 1991 Corvette: Service Bulletin: Damaged ECM/PCM Mis-Diagnosis Due to Incorrect &quot;Tap-Testing&quot; Procedures</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-1972-corvette-service-bulletin-moisture-entering-pulse-amplifier-transistor-ignition-systems-932.html</guid>
										<title>1965 - 1972 Corvette:  Service Bulletin:  Moisture Entering Pulse Amplifier - Transistor Ignition Systems</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-1972-corvette-service-bulletin-moisture-entering-pulse-amplifier-transistor-ignition-systems-932.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1972-corvette-service-news-headlamp-circuit-diagnosis-1101.html</guid>
										<title>1972 Corvette:  Service News:  Headlamp Circuit Diagnosis</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1972-corvette-service-news-headlamp-circuit-diagnosis-1101.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-engineering-service-letter-discharged-battery-906.html</guid>
										<title>1968 Corvette:  Engineering Service Letter:  Discharged Battery</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-engineering-service-letter-discharged-battery-906.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-chevrolet-service-news-1968-corvette-courtesy-light-inoperative-1240.html</guid>
										<title>1968 Corvette:  Chevrolet Service News:  1968 Corvette Courtesy Light Inoperative</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-chevrolet-service-news-1968-corvette-courtesy-light-inoperative-1240.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-news-headlamp-aiming-procedure-1205.html</guid>
										<title>1968 Corvette:  Service News:  Headlamp Aiming Procedure</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-news-headlamp-aiming-procedure-1205.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1978-1980-corvette-service-news-speedometer-system-noise-diagnosis-and-repair-1188.html</guid>
										<title>1978 - 1980 Corvette:  Service News:  Speedometer System Noise Diagnosis and Repair</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1978-1980-corvette-service-news-speedometer-system-noise-diagnosis-and-repair-1188.html</link>
