<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-dealer-installed-anchor-for-child-seat-with-top-strap-anchor-installation-945.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1994-1996-corvette-service-bulletin-door-trim-arm-rest-lid-hard-to-open-or-close-hinge-binding-replace-hinge-1019.html</guid>
										<title>1994 - 1996 Corvette:  Service Bulletin:  Door Trim Arm Rest Lid Hard to Open or Close, Hinge Binding (Replace Hinge)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1994-1996-corvette-service-bulletin-door-trim-arm-rest-lid-hard-to-open-or-close-hinge-binding-replace-hinge-1019.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-corvette-service-bulletin-1988-anniversary-model-discolored-door-armrest-658.html</guid>
										<title>1988 Corvette: Service Bulletin: 1988 Anniversary Model: Discolored Door Armrest</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-corvette-service-bulletin-1988-anniversary-model-discolored-door-armrest-658.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1991-corvette-recall-left-right-side-safety-belt-retractor-replacement-508.html</guid>
										<title>1984 - 1991 Corvette: Recall: Left &amp; Right Side Safety Belt Retractor Replacement</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1991-corvette-recall-left-right-side-safety-belt-retractor-replacement-508.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1996-corvette-inner-door-panel-screw-locations-503.html</guid>
										<title>1990 - 1996 Corvette: Inner Door Panel Screw Locations</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1996-corvette-inner-door-panel-screw-locations-503.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-inflatable-lumbar-seat-repair-on-c4-corvette-498.html</guid>
										<title>Technical Article:  Inflatable Lumbar Seat Repair on C4 Corvette</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-inflatable-lumbar-seat-repair-on-c4-corvette-498.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1987-corvette-service-bulletin-loose-corvette-door-trim-panel-510.html</guid>
										<title>1984 - 1987 Corvette: Service Bulletin: Loose Corvette Door Trim Panel</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1987-corvette-service-bulletin-loose-corvette-door-trim-panel-510.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-corvette-service-bulletin-squeak-and-rattle-diagnosis-guide-499.html</guid>
										<title>1991 Corvette: Service Bulletin: Squeak and Rattle Diagnosis Guide</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-corvette-service-bulletin-squeak-and-rattle-diagnosis-guide-499.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1980-1990-corvette-service-bulletin-loose-carpet-on-side-wall-trim-pads-repair-procedure-683.html</guid>
										<title>1980 - 1990 Corvette: Service Bulletin: Loose Carpet on Side Wall Trim Pads (Repair Procedure)</title>
