<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-cracking-of-the-plenum-at-the-right-hood-latch-plate-944.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-auxiliary-hardtop-and-stowage-compartment-door-items-931.html</guid>
										<title>1968 Corvette:  Service Bulletin:  Auxiliary Hardtop and Stowage Compartment Door Items</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-auxiliary-hardtop-and-stowage-compartment-door-items-931.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-service-bulletin-rear-window-water-leak-1117.html</guid>
										<title>1973 Corvette:  Service Bulletin:  Rear Window Water Leak</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-service-bulletin-rear-window-water-leak-1117.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-lubrication-of-window-regulator-shaft-719.html</guid>
										<title>1968 Corvette: Service Bulletin: Lubrication of Window Regulator Shaft</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-lubrication-of-window-regulator-shaft-719.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-inter-organization-letter-water-leaks-1968-corvette-aero-coupe-and-convertible-supplement-to-a-i-68-11-1112.html</guid>
										<title>1968 Corvette: Inter-Organization Letter:  Water Leaks - 1968 Corvette Aero-Coupe and Convertible Supplement to A.I. 68-11</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-inter-organization-letter-water-leaks-1968-corvette-aero-coupe-and-convertible-supplement-to-a-i-68-11-1112.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1970-1973-corvette-service-bulletin-engine-overheat-1220.html</guid>
										<title>1970 - 1973 Corvette:  Service Bulletin:  Engine Overheat</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1970-1973-corvette-service-bulletin-engine-overheat-1220.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-corvette-service-bulletin-headlamp-opening-interference-696.html</guid>
										<title>1969 Corvette: Service Bulletin: Headlamp Opening Interference</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-corvette-service-bulletin-headlamp-opening-interference-696.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1970-corvette-service-bulletin-1970-corvette-folding-top-material-interference-with-lid-pin-support-980.html</guid>
										<title>1970 Corvette:  Service Bulletin:  1970 Corvette Folding Top Material Interference with Lid Pin Support</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1970-corvette-service-bulletin-1970-corvette-folding-top-material-interference-with-lid-pin-support-980.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1972-corvette-service-news-front-fender-skirt-availability-1211.html</guid>
										<title>1972 Corvette:  Service News:  Front Fender Skirt Availability</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1972-corvette-service-news-front-fender-skirt-availability-1211.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-news-corvette-folding-top-compartment-lid-to-folding-top-interference-sn-68-20-872.html</guid>
										<title>1968 Corvette: Service News: Corvette Folding Top Compartment Lid to Folding Top Interference (SN-68-20)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-news-corvette-folding-top-compartment-lid-to-folding-top-interference-sn-68-20-872.html</link>
