<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-corvette-service-news-fuel-injection-diagnosis-chart-937.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1970-corvette-service-news-1970-carburetor-linkage-and-accelerator-controls-679.html</guid>
										<title>1970 Corvette: Service News: 1970 Carburetor Linkage and Accelerator Controls</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1970-corvette-service-news-1970-carburetor-linkage-and-accelerator-controls-679.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-1991-corvette-service-bulletin-parasitic-drain-on-battery-ammeter-connecting-procedure-689.html</guid>
										<title>1982 - 1991 Corvette: Service Bulletin: Parasitic Drain on Battery Ammeter Connecting Procedure</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-gas-line-rattle-981.html</guid>
										<title>1968 Corvette:  Service Bulletin:  Gas Line Rattle</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-gas-line-rattle-981.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1970-corvette-service-news-valve-rocker-arm-stud-replacement-1208.html</guid>
										<title>1970 Corvette:  Service News:  Valve Rocker Arm Stud Replacement</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1970-corvette-service-news-valve-rocker-arm-stud-replacement-1208.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1977-corvette-service-bulletin-anti-theft-alarm-system-interim-modifications-1094.html</guid>
										<title>1977 Corvette:  Service Bulletin:  Anti-Theft Alarm System Interim Modifications</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1977-corvette-service-bulletin-anti-theft-alarm-system-interim-modifications-1094.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-electrical-schematic-wiper-washer-system-212.html</guid>
										<title>2006 Corvette:  Electrical Schematic: Wiper Washer System</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-electrical-schematic-wiper-washer-system-212.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-heat-damage-to-engine-wiring-harness-943.html</guid>
										<title>1968 Corvette:  Service Bulletin:  Heat Damage to Engine Wiring Harness</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-heat-damage-to-engine-wiring-harness-943.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1976-corvette-parts-chart-delco-quadrajet-carburetors-1064.html</guid>
										<title>1976 Corvette:  Parts Chart:  Delco Quadrajet Carburetors</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1976-corvette-parts-chart-delco-quadrajet-carburetors-1064.html</link>
