<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1980-1982-corvette-service-news-differential-side-bearing-removal-936.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1982-corvette-technical-article-in-vehicle-corvette-steering-gear-adjustment-91.html</guid>
										<title>1963 - 1982 Corvette: Technical Article: In-Vehicle Corvette Steering Gear Adjustment</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1982-corvette-technical-article-in-vehicle-corvette-steering-gear-adjustment-91.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-news-spark-plug-removal-with-427-engine-and-a-c-680.html</guid>
										<title>1968 Corvette: Service News: Spark Plug Removal with 427 Engine and A/C</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-news-spark-plug-removal-with-427-engine-and-a-c-680.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1980-corvette-service-bulletin-rear-wheel-spindle-yoke-snapping-noise-985.html</guid>
										<title>1980 Corvette:  Service Bulletin:  Rear Wheel Spindle Yoke Snapping Noise</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1980-corvette-service-bulletin-rear-wheel-spindle-yoke-snapping-noise-985.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-corvette-service-news-fuel-injection-diagnosis-chart-revision-844.html</guid>
										<title>1982 Corvette: Service News: Fuel injection Diagnosis Chart Revision</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-corvette-service-news-fuel-injection-diagnosis-chart-revision-844.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-service-news-red-idle-mixture-screw-caps-822.html</guid>
										<title>1973 Corvette: Service News: Red Idle Mixture Screw Caps</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-service-news-red-idle-mixture-screw-caps-822.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1970-corvette-service-news-1970-carburetor-linkage-and-accelerator-controls-679.html</guid>
										<title>1970 Corvette: Service News: 1970 Carburetor Linkage and Accelerator Controls</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1970-corvette-service-news-1970-carburetor-linkage-and-accelerator-controls-679.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1978-1979-corvette-service-news-access-to-right-upper-control-arm-attaching-bolt-706.html</guid>
										<title>1978 - 1979 Corvette: Service News: Access to Right Upper Control Arm Attaching Bolt</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1978-1979-corvette-service-news-access-to-right-upper-control-arm-attaching-bolt-706.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1975-corvette-service-news-radiator-and-fan-shroud-removal-1046.html</guid>
										<title>1975 Corvette:  Service News:  Radiator and Fan Shroud Removal</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1975-corvette-service-news-radiator-and-fan-shroud-removal-1046.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-engineering-service-letter-upper-radiator-hose-alignment-25.html</guid>
										<title>1968 Corvette:  Engineering Service Letter:  Upper Radiator Hose Alignment</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-engineering-service-letter-upper-radiator-hose-alignment-25.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-1969-corvette-tech-article-building-427-engines-corvette-news-1274.html</guid>
										<title>1966 - 1969 Corvette: Tech Article:  Building 427 Engines - Corvette News</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-1969-corvette-tech-article-building-427-engines-corvette-news-1274.html</link>
