										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-revised-engine-removal-procedures-545.html</guid>
										<title>1984 Corvette: Service Bulletin: Revised Engine Removal Procedures</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-revised-engine-removal-procedures-545.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-rack-pinion-power-steering-valve-ring-service-627.html</guid>
										<title>1984 Corvette: Service Bulletin: Rack / Pinion Power Steering Valve Ring Service</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-rack-pinion-power-steering-valve-ring-service-627.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1995-corvette-recall-distributor-vacuum-vent-harness-518.html</guid>
										<title>1995 Corvette: Recall: Distributor Vacuum Vent Harness</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1995-corvette-recall-distributor-vacuum-vent-harness-518.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1996-corvette-oil-life-monitor-reset-the-engine-oil-life-monitor-531.html</guid>
										<title>1990 - 1996 Corvette: Oil Life Monitor: Reset the Engine Oil Life Monitor</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-1996-corvette-oil-life-monitor-reset-the-engine-oil-life-monitor-531.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1986-corvette-service-bulletin-power-steering-fluid-cooler-630.html</guid>
										<title>1984 - 1986 Corvette: Service Bulletin: Power Steering Fluid Cooler</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1986-corvette-service-bulletin-power-steering-fluid-cooler-630.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1993-corvette-service-bulletin-steering-column-popping-noise-616.html</guid>
										<title>1992 - 1993 Corvette: Service Bulletin: Steering Column Popping Noise</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1993-corvette-service-bulletin-steering-column-popping-noise-616.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-gm-techlink-rear-spindle-support-rod-protector-sleeve-625.html</guid>
										<title>1984 Corvette: GM TechLink: Rear Spindle Support Rod Protector Sleeve</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-gm-techlink-rear-spindle-support-rod-protector-sleeve-625.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1985-1991-corvette-l98-engine-throttle-body-diagram-542.html</guid>
										<title>1985 - 1991 Corvette: L98 Engine Throttle Body Diagram</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1985-1991-corvette-l98-engine-throttle-body-diagram-542.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1994-1995-corvette-service-bulletin-information-on-air-intake-duct-installation-521.html</guid>
										<title>1994 - 1995 Corvette: Service Bulletin: Information on Air Intake Duct Installation</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1994-1995-corvette-service-bulletin-information-on-air-intake-duct-installation-521.html</link>
