<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-1972-corvette-service-news-ignition-pulse-amplifier-sn-c-1-933.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-electrical-schematic-power-windows-189.html</guid>
										<title>1973 Corvette:  Electrical Schematic:  Power Windows</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-electrical-schematic-power-windows-189.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-heat-damage-to-engine-wiring-harness-at-starter-solenoid-1027.html</guid>
										<title>1968 Corvette:  Service Bulletin:  Heat Damage to Engine Wiring Harness at Starter Solenoid</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-heat-damage-to-engine-wiring-harness-at-starter-solenoid-1027.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-corvette-service-news-servicing-the-breakerless-ignition-system-916.html</guid>
										<title>1964 Corvette:  Service News:  Servicing the Breakerless Ignition System</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-corvette-service-news-servicing-the-breakerless-ignition-system-916.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-electrical-schematic-engine-192.html</guid>
										<title>1973 Corvette:  Electrical Schematic: Engine</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-electrical-schematic-engine-192.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-1964-corvette-chevrolet-partsmart-bulb-and-fuse-charts-1088.html</guid>
										<title>1955 - 1964 Corvette:  Chevrolet PartsMart:  Bulb and Fuse Charts</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-1964-corvette-chevrolet-partsmart-bulb-and-fuse-charts-1088.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-electrical-schematic-rear-window-defogger-188.html</guid>
										<title>1973 Corvette:  Electrical Schematic:  Rear Window Defogger</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-electrical-schematic-rear-window-defogger-188.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-delco-service-bulletins-delco-radio-service-1171.html</guid>
										<title>1963 Corvette:  Delco Service Bulletins:  Delco Radio Service</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-delco-service-bulletins-delco-radio-service-1171.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-corvette-inter-organization-letter-1969-delcotron-generator-with-integrated-voltage-regulator-1133.html</guid>
										<title>1969 Corvette:  Inter-Organization Letter:  1969 Delcotron Generator with Integrated Voltage Regulator</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-corvette-inter-organization-letter-1969-delcotron-generator-with-integrated-voltage-regulator-1133.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-corvette-engineering-service-letter-muncie-four-speed-transmission-design-change-1072.html</guid>
										<title>1964 Corvette:  Engineering Service Letter:  Muncie Four Speed Transmission Design Change</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-corvette-engineering-service-letter-muncie-four-speed-transmission-design-change-1072.html</link>
