<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1962-corvette-service-bulletin-transmission-identification-information-928.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1962-corvette-service-bulletin-excessive-idle-speed-908.html</guid>
										<title>1962 Corvette:  Service Bulletin:  Excessive Idle Speed</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1962-corvette-service-bulletin-excessive-idle-speed-908.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-hard-shifting-1216.html</guid>
										<title>1955 Corvette:  Service Bulletin:  Hard Shifting</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-hard-shifting-1216.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1954-corvette-service-bulletin-vacuum-modulator-spring-throttle-valve-inner-spring-1126.html</guid>
										<title>1954 Corvette:  Service Bulletin:  Vacuum Modulator Spring Throttle Valve Inner Spring</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1954-corvette-service-bulletin-vacuum-modulator-spring-throttle-valve-inner-spring-1126.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1962-1963-corvette-service-bulletin-governor-rattle-after-reverse-operation-967.html</guid>
										<title>1962 - 1963 Corvette:  Service Bulletin:  Governor Rattle After Reverse Operation</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1962-1963-corvette-service-bulletin-governor-rattle-after-reverse-operation-967.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1962-corvette-service-bulletin-aluminum-powerglide-shift-problems-1037.html</guid>
										<title>1962 Corvette:  Service Bulletin:  Aluminum Powerglide Shift Problems</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1962-corvette-service-bulletin-aluminum-powerglide-shift-problems-1037.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1958-corvette-service-bulletin-automatic-transmission-fluid-783.html</guid>
										<title>1958 Corvette: Service Bulletin: Automatic Transmission Fluid</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1958-corvette-service-bulletin-automatic-transmission-fluid-783.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-1958-corvette-service-news-corvette-4-speed-transmission-harsh-shift-into-third-speed-789.html</guid>
										<title>1957 - 1958 Corvette: Service News: Corvette 4-Speed Transmission - Harsh Shift Into Third Speed</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-1958-corvette-service-news-corvette-4-speed-transmission-harsh-shift-into-third-speed-789.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-upshift-at-part-throttle-1110.html</guid>
										<title>1955 Corvette:  Service Bulletin:  Upshift at Part Throttle</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-upshift-at-part-throttle-1110.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-corvette-service-bulletin-powerglide-transmission-slippage-and-chatter-in-automatic-low-and-drive-range-81.html</guid>
										<title>1953 Corvette:  Service Bulletin:  Powerglide Transmission Slippage and Chatter in Automatic Low and Drive Range</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-corvette-service-bulletin-powerglide-transmission-slippage-and-chatter-in-automatic-low-and-drive-range-81.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1962-corvette-service-bulletin-aluminum-powerglide-valve-body-governor-and-rear-pump-changes-1156.html</guid>
										<title>1962 Corvette:  Service Bulletin:  Aluminum Powerglide Valve Body, Governor and Rear Pump Changes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1962-corvette-service-bulletin-aluminum-powerglide-valve-body-governor-and-rear-pump-changes-1156.html</link>
