<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-1970-corvette-service-bulletin-depressed-park-windshield-wipers-unable-to-park-915.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-1972-corvette-service-bulletin-moisture-entering-pulse-amplifier-transistor-ignition-systems-932.html</guid>
										<title>1965 - 1972 Corvette:  Service Bulletin:  Moisture Entering Pulse Amplifier - Transistor Ignition Systems</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-1972-corvette-service-bulletin-moisture-entering-pulse-amplifier-transistor-ignition-systems-932.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1976-1977-corvette-service-bulletin-use-of-1976-model-ignition-key-sets-in-1977-chevrolet-passenger-vehicles-1251.html</guid>
										<title>1976 - 1977 Corvette:  Service Bulletin:  Use of 1976 Model Ignition Key Sets in 1977 Chevrolet Passenger Vehicles</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1976-1977-corvette-service-bulletin-use-of-1976-model-ignition-key-sets-in-1977-chevrolet-passenger-vehicles-1251.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1981-corvette-service-bulletin-glow-around-wiper-switch-rework-wiper-switch-bezel-692.html</guid>
										<title>1981 Corvette: Service Bulletin: Glow Around Wiper Switch Rework Wiper Switch Bezel</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1981-corvette-service-bulletin-glow-around-wiper-switch-rework-wiper-switch-bezel-692.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-1982-corvette-delco-service-bulletin-quadrajet-carburetor-service-charts-1135.html</guid>
										<title>1968 - 1982 Corvette:  Delco Service Bulletin:  Quadrajet Carburetor Service Charts</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-1982-corvette-delco-service-bulletin-quadrajet-carburetor-service-charts-1135.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-1991-corvette-service-bulletin-damaged-ecm-pcm-mis-diagnosis-due-to-incorrect-tap-testing-procedures-690.html</guid>
										<title>1982 - 1991 Corvette: Service Bulletin: Damaged ECM/PCM Mis-Diagnosis Due to Incorrect &quot;Tap-Testing&quot; Procedures</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-windshield-wiper-system-operation-and-diagnosis-697.html</guid>
										<title>1968 Corvette: Service Bulletin: Windshield Wiper System - Operation and Diagnosis</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-windshield-wiper-system-operation-and-diagnosis-697.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-corvette-engineering-service-letter-speedometer-shaft-failure-24.html</guid>
										<title>1969 Corvette: Engineering Service Letter:  Speedometer Shaft Failure</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-corvette-engineering-service-letter-speedometer-shaft-failure-24.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-news-headlamp-aiming-procedure-1205.html</guid>
										<title>1968 Corvette:  Service News:  Headlamp Aiming Procedure</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-news-headlamp-aiming-procedure-1205.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-engineering-service-letter-engine-harness-replacement-corvette-transistor-ignition-914.html</guid>
										<title>1968 Corvette:  Engineering Service Letter:  Engine Harness Replacement Corvette Transistor Ignition</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-engineering-service-letter-engine-harness-replacement-corvette-transistor-ignition-914.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-corvette-advance-information-inter-organization-letter-anti-theft-audio-alarm-1256.html</guid>
										<title>1969 Corvette:  Advance Information Inter-Organization Letter:  Anti-Theft Audio Alarm</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-corvette-advance-information-inter-organization-letter-anti-theft-audio-alarm-1256.html</link>
