<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-engineering-service-letter-engine-harness-replacement-corvette-transistor-ignition-914.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-electrical-schematics-193.html</guid>
										<title>1973 Corvette: Electrical Schematics</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-electrical-schematics-193.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1971-corvette-service-bulletin-anti-diesel-relay-1164.html</guid>
										<title>1971 Corvette:  Service Bulletin:  Anti-Diesel Relay</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1971-corvette-service-bulletin-anti-diesel-relay-1164.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-1970-corvette-service-bulletin-voltage-regulator-failures-in-the-1970-integrated-delcotrons-865.html</guid>
										<title>1969 - 1970 Corvette: Service Bulletin: Voltage Regulator Failures in the 1970 Integrated Delcotrons</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-1970-corvette-service-bulletin-voltage-regulator-failures-in-the-1970-integrated-delcotrons-865.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-corvette-inter-organization-letter-1969-delcotron-generator-with-integrated-voltage-regulator-1133.html</guid>
										<title>1969 Corvette:  Inter-Organization Letter:  1969 Delcotron Generator with Integrated Voltage Regulator</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-corvette-inter-organization-letter-1969-delcotron-generator-with-integrated-voltage-regulator-1133.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-electrical-schematic-engine-192.html</guid>
										<title>1973 Corvette:  Electrical Schematic: Engine</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-electrical-schematic-engine-192.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-1970-corvette-service-bulletin-depressed-park-windshield-wipers-unable-to-park-915.html</guid>
										<title>1968 - 1970 Corvette:  Service Bulletin:  Depressed Park Windshield Wipers Unable to Park</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-1970-corvette-service-bulletin-depressed-park-windshield-wipers-unable-to-park-915.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-1969-corvette-engineering-service-letter-heat-shield-starting-motor-solenoid-907.html</guid>
										<title>1968 - 1969 Corvette:  Engineering Service Letter:  Heat Shield - Starting Motor Solenoid</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-1969-corvette-engineering-service-letter-heat-shield-starting-motor-solenoid-907.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1977-corvette-service-bulletin-anti-theft-alarm-switch-protective-grease-1104.html</guid>
										<title>1977 Corvette:  Service Bulletin:  Anti-Theft Alarm Switch - Protective Grease</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1977-corvette-service-bulletin-anti-theft-alarm-switch-protective-grease-1104.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-news-1968-corvette-327-cu-in-engine-distributor-alignment-1092.html</guid>
										<title>1968 Corvette:  Service News:  1968 Corvette 327 Cu. In. Engine Distributor Alignment</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-news-1968-corvette-327-cu-in-engine-distributor-alignment-1092.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-corvette-service-news-fuel-injection-diagnosis-chart-937.html</guid>
										<title>1982 Corvette: Service News: Fuel injection Diagnosis Chart</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-corvette-service-news-fuel-injection-diagnosis-chart-937.html</link>
