<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-corvette-fuel-injection-fuel-meter-pump-drive-shaft-seal-replacement-911.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-1963-corvette-service-news-new-fuel-injection-service-kits-available-927.html</guid>
										<title>1957 - 1963 Corvette:  Service News:  New Fuel Injection Service Kits Available</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-1963-corvette-service-news-new-fuel-injection-service-kits-available-927.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-corvette-service-bulletin-oil-consumption-990.html</guid>
										<title>1959 Corvette:  Service Bulletin:  Oil Consumption</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-corvette-service-bulletin-oil-consumption-990.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-corvette-service-bulletin-decal-added-to-air-cleaner-to-aid-installation-and-prevent-carburetor-linkage-interference-942.html</guid>
										<title>1959 Corvette:  Service Bulletin:  Decal Added to Air Cleaner to Aid Installation and Prevent Carburetor Linkage Interference</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-corvette-service-bulletin-decal-added-to-air-cleaner-to-aid-installation-and-prevent-carburetor-linkage-interference-942.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-corvette-field-service-bulletin-throttle-return-spring-kit-770.html</guid>
										<title>1957 Corvette: Field Service Bulletin: Throttle Return Spring Kit</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-corvette-field-service-bulletin-throttle-return-spring-kit-770.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-1956-corvette-service-bulletin-oil-level-gauge-accuracy-774.html</guid>
										<title>1955 - 1956 Corvette: Service Bulletin: Oil Level Gauge - Accuracy</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-1956-corvette-service-bulletin-oil-level-gauge-accuracy-774.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1962-corvette-technical-information-carter-afb-carburetor-revisions-163.html</guid>
										<title>1962 Corvette: Technical Information: Carter AFB Carburetor Revisions</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1962-corvette-technical-information-carter-afb-carburetor-revisions-163.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1954-corvette-service-bulletin-new-valve-spring-high-lift-cam-engines-775.html</guid>
										<title>1954 Corvette: Service Bulletin: New Valve Spring - High Lift Cam Engines</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1954-corvette-service-bulletin-new-valve-spring-high-lift-cam-engines-775.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1959-corvette-chevrolet-partsmart-connecting-rod-piston-crankshaft-part-numbers-1085.html</guid>
										<title>1953 - 1959 Corvette:  Chevrolet PartsMart:  Connecting Rod, Piston, Crankshaft Part Numbers</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1959-corvette-chevrolet-partsmart-connecting-rod-piston-crankshaft-part-numbers-1085.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-corvette-inter-organization-letters-fuel-injection-issues-1146.html</guid>
										<title>1957 Corvette:  Inter-Organization Letters:  Fuel Injection Issues</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-corvette-inter-organization-letters-fuel-injection-issues-1146.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-1960-corvette-service-bulletin-calibration-revised-to-correct-lean-condition-at-wide-open-throttle-955.html</guid>
										<title>1959 - 1960 Corvette:  Service Bulletin:  Calibration Revised to Correct Lean Condition at Wide Open Throttle</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-1960-corvette-service-bulletin-calibration-revised-to-correct-lean-condition-at-wide-open-throttle-955.html</link>
