<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-engineering-service-letter-discharged-battery-906.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1978-corvette-service-bulletin-tamper-resistant-choke-1170.html</guid>
										<title>1978 Corvette:  Service Bulletin:  Tamper Resistant Choke</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1978-corvette-service-bulletin-tamper-resistant-choke-1170.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1978-1979-corvette-service-bulletin-power-antenna-operation-124.html</guid>
										<title>1978 - 1979 Corvette: Service Bulletin: Power Antenna Operation</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1978-1979-corvette-service-bulletin-power-antenna-operation-124.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-electrical-schematic-automatic-transmission-kickdown-switch-191.html</guid>
										<title>1973 Corvette:  Electrical Schematic:  Automatic Transmission Kickdown Switch</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-electrical-schematic-automatic-transmission-kickdown-switch-191.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-1991-corvette-service-bulletin-damaged-ecm-pcm-mis-diagnosis-due-to-incorrect-tap-testing-procedures-690.html</guid>
										<title>1982 - 1991 Corvette: Service Bulletin: Damaged ECM/PCM Mis-Diagnosis Due to Incorrect &quot;Tap-Testing&quot; Procedures</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-electrical-schematic-rear-window-defogger-188.html</guid>
										<title>1973 Corvette:  Electrical Schematic:  Rear Window Defogger</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-electrical-schematic-rear-window-defogger-188.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-1991-corvette-service-bulletin-parasitic-drain-on-battery-ammeter-connecting-procedure-689.html</guid>
										<title>1982 - 1991 Corvette: Service Bulletin: Parasitic Drain on Battery Ammeter Connecting Procedure</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-electrical-schematic-power-windows-189.html</guid>
										<title>1973 Corvette:  Electrical Schematic:  Power Windows</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-electrical-schematic-power-windows-189.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-1991-corvette-service-bulletin-checking-connector-terminal-contact-metri-pack-691.html</guid>
										<title>1982 - 1991 Corvette: Service Bulletin: Checking Connector Terminal Contact - Metri-Pack</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-1991-corvette-service-bulletin-checking-connector-terminal-contact-metri-pack-691.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-corvette-advance-information-inter-organization-letter-anti-theft-audio-alarm-1256.html</guid>
										<title>1969 Corvette:  Advance Information Inter-Organization Letter:  Anti-Theft Audio Alarm</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-corvette-advance-information-inter-organization-letter-anti-theft-audio-alarm-1256.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-corvette-ecm-codes-688.html</guid>
										<title>1982 Corvette: ECM Codes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-corvette-ecm-codes-688.html</link>
