<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-corvette-service-bulletin-temperature-gauge-erratic-during-normalizing-period-902.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-corvette-service-bulletin-spark-plug-fouling-idle-adjustment-975.html</guid>
										<title>1956 Corvette:  Service Bulletin:  Spark Plug Fouling - Idle Adjustment</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-corvette-service-bulletin-spark-plug-fouling-idle-adjustment-975.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1960-1961-corvette-zone-letter-aluminum-radiator-replacement-763.html</guid>
										<title>1960 - 1961 Corvette: Zone Letter: Aluminum Radiator Replacement</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1960-1961-corvette-zone-letter-aluminum-radiator-replacement-763.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1960-corvette-service-bulletin-correction-for-erratic-tachometer-operation-952.html</guid>
										<title>1960 Corvette:  Service Bulletin:  Correction for Erratic Tachometer Operation</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1960-corvette-service-bulletin-correction-for-erratic-tachometer-operation-952.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1958-corvette-service-bulletin-siphon-breaker-plate-unit-7014900-fuel-injection-766.html</guid>
										<title>1958 Corvette: Service Bulletin: Siphon Breaker Plate Unit #7014900 Fuel Injection</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1958-corvette-service-bulletin-siphon-breaker-plate-unit-7014900-fuel-injection-766.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1958-corvette-service-bulletin-fuel-filter-element-maintenance-777.html</guid>
										<title>1953 - 1958 Corvette: Service Bulletin: Fuel Filter Element Maintenance</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1958-corvette-service-bulletin-fuel-filter-element-maintenance-777.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-1965-corvette-fuel-injection-specifications-1140.html</guid>
										<title>1957 - 1965 Corvette:  Fuel Injection Specifications</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-corvette-field-service-bulletin-throttle-return-spring-kit-770.html</guid>
										<title>1957 Corvette: Field Service Bulletin: Throttle Return Spring Kit</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-corvette-field-service-bulletin-throttle-return-spring-kit-770.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-corvette-service-bulletin-horn-relay-problems-162.html</guid>
										<title>1956 Corvette: Service Bulletin: Horn Relay Problems</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-corvette-service-bulletin-horn-relay-problems-162.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1960-1962-corvette-chevrolet-central-office-letter-aluminum-radiator-factory-replacement-policy-762.html</guid>
										<title>1960 - 1962 Corvette: Chevrolet Central Office Letter: Aluminum Radiator Factory Replacement Policy</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1960-1962-corvette-chevrolet-central-office-letter-aluminum-radiator-factory-replacement-policy-762.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-1959-corvette-chevrolet-partsmart-distributors-and-starter-motors-1042.html</guid>
										<title>1955 - 1959 Corvette:  Chevrolet PartSmart:  Distributors and Starter Motors</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-1959-corvette-chevrolet-partsmart-distributors-and-starter-motors-1042.html</link>
