<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-1961-corvette-service-news-fuel-injection-change-901.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1959-corvette-chevrolet-partsmart-connecting-rod-piston-crankshaft-part-numbers-1085.html</guid>
										<title>1953 - 1959 Corvette:  Chevrolet PartsMart:  Connecting Rod, Piston, Crankshaft Part Numbers</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1959-corvette-chevrolet-partsmart-connecting-rod-piston-crankshaft-part-numbers-1085.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-v8-engines-771.html</guid>
										<title>1955 Corvette: Service Bulletin: V8 Engines</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-v8-engines-771.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-corvette-service-bulletin-1957-passenger-car-and-truck-camshaft-identification-769.html</guid>
										<title>1957 Corvette: Service Bulletin: 1957 Passenger Car and Truck Camshaft Identification</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-corvette-service-bulletin-1957-passenger-car-and-truck-camshaft-identification-769.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-corvette-service-bulletin-board-parts-mart-magazine-tune-up-specifications-947.html</guid>
										<title>1959 Corvette:  Service Bulletin Board - Parts Mart Magazine - Tune-Up Specifications</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-corvette-service-bulletin-board-parts-mart-magazine-tune-up-specifications-947.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-1958-corvette-service-bulletin-skinner-oil-savers-for-1958-and-older-model-v-8-engines-1052.html</guid>
										<title>1955 - 1958 Corvette:  Service Bulletin:  Skinner Oil Savers for 1958 and Older Model V-8 Engines</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-1958-corvette-service-bulletin-skinner-oil-savers-for-1958-and-older-model-v-8-engines-1052.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-corvette-service-news-fuel-injection-pump-drive-shaft-installation-177.html</guid>
										<title>1957 Corvette: Service News: Fuel Injection Pump Drive Shaft Installation</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1957-corvette-service-news-fuel-injection-pump-drive-shaft-installation-177.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1959-corvette-connecting-rod-bearing-part-numbers-776.html</guid>
										<title>1953 - 1959 Corvette: Connecting Rod Bearing Part Numbers</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1959-corvette-connecting-rod-bearing-part-numbers-776.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-1956-corvette-service-bulletin-inlet-manifold-oil-guards-1254.html</guid>
										<title>1955 - 1956 Corvette:  Service Bulletin:  Inlet Manifold Oil Guards</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-1956-corvette-service-bulletin-inlet-manifold-oil-guards-1254.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-specification-sheets-for-the-adjustment-and-parts-sizes-for-the-four-barrel-carburetor-1141.html</guid>
										<title>1955 Corvette:  Service Bulletin:  Specification Sheets for the Adjustment and Parts Sizes for the Four Barrel Carburetor</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1955-corvette-service-bulletin-specification-sheets-for-the-adjustment-and-parts-sizes-for-the-four-barrel-carburetor-1141.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-corvette-service-news-powerglide-transmission-850.html</guid>
										<title>1953 Corvette: Service News: Powerglide Transmission</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-corvette-service-news-powerglide-transmission-850.html</link>
