<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-how-to-repair-rebuild-your-alternator-90.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/tire-storage-recommendations-298.html</guid>
										<title>Tire Storage Recommendations</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/tire-storage-recommendations-298.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-how-to-set-up-a-bg-speed-demon-basic-89.html</guid>
										<title>Technical Article: How to Set Up a BG Speed Demon (basic)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-how-to-set-up-a-bg-speed-demon-basic-89.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/all-corvettes-service-bulletin-removal-of-tight-wheels-1189.html</guid>
										<title>All Corvettes:  Service Bulletin:  Removal of Tight Wheels</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/all-corvettes-service-bulletin-removal-of-tight-wheels-1189.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-leak-less-swapping-the-centerhead-in-your-corvette-and-keeping-leaks-at-bay-238.html</guid>
										<title>Technical Article: Leak Less - Swapping the Centerhead in Your Corvette and Keeping Leaks at Bay</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-leak-less-swapping-the-centerhead-in-your-corvette-and-keeping-leaks-at-bay-238.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/determining-the-resistance-value-of-the-ignition-key-resistor-pellet-291.html</guid>
										<title>Determining the Resistance Value of the Ignition Key Resistor Pellet</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/determining-the-resistance-value-of-the-ignition-key-resistor-pellet-291.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-riveting-experience-home-restorer-s-guide-to-installing-soft-aluminum-rivets-on-your-corvette-245.html</guid>
										<title>Technical Article:  Riveting Experience - Home-Restorer`s Guide to Installing Soft Aluminum Rivets on your Corvette</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-riveting-experience-home-restorer-s-guide-to-installing-soft-aluminum-rivets-on-your-corvette-245.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/service-bulletin-delco-freedom-battery-diagnosis-information-292.html</guid>
										<title>Service Bulletin: Delco Freedom Battery Diagnosis Information</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/service-bulletin-delco-freedom-battery-diagnosis-information-292.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/paint-orange-peel-as-it-applies-to-corvette-paint-quality-296.html</guid>
										<title>Paint: Orange Peel as it Applies to Corvette Paint Quality</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/paint-orange-peel-as-it-applies-to-corvette-paint-quality-296.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/gm-press-release-april-22-1996-zora-arkus-duntov-833.html</guid>
										<title>GM Press Release:  April 22, 1996: Zora Arkus-Duntov</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-long-term-winter-corvette-storage-299.html</guid>
										<title>Technical Article: Long Term / Winter Corvette Storage</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-long-term-winter-corvette-storage-299.html</link>
