<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-corvette-recall-notice-anti-skid-brake-system-master-cylinder-center-valve-895.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-recall-front-brake-caliper-bracket-bolt-644.html</guid>
										<title>1984 Corvette: Recall: Front Brake Caliper Bracket Bolt</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-recall-front-brake-caliper-bracket-bolt-644.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1981-1990-corvette-service-bulletin-brake-rotor-refinish-parts-ordering-information-710.html</guid>
										<title>1981 - 1990 Corvette: Service Bulletin: Brake Rotor Refinish Parts Ordering Information</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1981-1990-corvette-service-bulletin-brake-rotor-refinish-parts-ordering-information-710.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-recall-inoperative-parking-brake-639.html</guid>
										<title>1990 Corvette: Recall: Inoperative Parking Brake</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-recall-inoperative-parking-brake-639.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-brake-squeal-642.html</guid>
										<title>1984 Corvette: Service Bulletin: Brake Squeal</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-brake-squeal-642.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-service-bulletin-change-in-brake-effectiveness-after-brake-work-632.html</guid>
										<title>1984 - 1996 Corvette: Service Bulletin: Change in Brake Effectiveness After Brake Work</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-service-bulletin-change-in-brake-effectiveness-after-brake-work-632.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-brake-pad-hold-down-spring-breakage-643.html</guid>
										<title>1984 Corvette: Service Bulletin: Brake Pad Hold-Down Spring Breakage</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-service-bulletin-brake-pad-hold-down-spring-breakage-643.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1993-corvette-service-bulletin-brake-service-light-abs-light-comes-on-false-code-83-636.html</guid>
										<title>1992 - 1993 Corvette: Service Bulletin: Brake Service Light/ABS Light Comes On (False Code 83)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-1993-corvette-service-bulletin-brake-service-light-abs-light-comes-on-false-code-83-636.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-technical-article-how-to-replace-your-front-brakes-86.html</guid>
										<title>1984 - 1996 Corvette: Technical Article: How to Replace Your Front Brakes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-technical-article-how-to-replace-your-front-brakes-86.html</link>
