<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-news-tune-up-specification-change-893.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-corvette-service-news-fuel-injection-diagnosis-chart-revision-844.html</guid>
										<title>1982 Corvette: Service News: Fuel injection Diagnosis Chart Revision</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-corvette-service-news-fuel-injection-diagnosis-chart-revision-844.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-news-spark-plug-removal-with-427-engine-and-a-c-680.html</guid>
										<title>1968 Corvette: Service News: Spark Plug Removal with 427 Engine and A/C</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-news-spark-plug-removal-with-427-engine-and-a-c-680.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1982-corvette-service-bulletin-cooling-system-restrictions-symptoms-and-diagnosis-1131.html</guid>
										<title>1963 - 1982 Corvette:  Service Bulletin:  Cooling System Restrictions - Symptoms and Diagnosis</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-features-sheet-chevrolet-l88-engine-assembly-features-1177.html</guid>
										<title>1968 Corvette:  Features Sheet:  Chevrolet L88 Engine Assembly Features</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-features-sheet-chevrolet-l88-engine-assembly-features-1177.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-corvette-service-news-fuel-injection-diagnosis-chart-937.html</guid>
										<title>1982 Corvette: Service News: Fuel injection Diagnosis Chart</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-corvette-service-news-fuel-injection-diagnosis-chart-937.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-corvette-service-bulletin-engine-coolant-usage-anti-freeze-specs-change-675.html</guid>
										<title>1982 Corvette: Service Bulletin: Engine Coolant Usage Anti-Freeze Specs Change</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-corvette-service-bulletin-engine-coolant-usage-anti-freeze-specs-change-675.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-cold-start-failure-1063.html</guid>
										<title>1968 Corvette:  Service Bulletin:  Cold Start Failure</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-cold-start-failure-1063.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-1969-corvette-tech-article-building-427-engines-corvette-news-1274.html</guid>
										<title>1966 - 1969 Corvette: Tech Article:  Building 427 Engines - Corvette News</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-1969-corvette-tech-article-building-427-engines-corvette-news-1274.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1970-corvette-service-news-1970-carburetor-linkage-and-accelerator-controls-1051.html</guid>
										<title>1970 Corvette:  Service News:  1970 Carburetor Linkage and Accelerator Controls</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1970-corvette-service-news-1970-carburetor-linkage-and-accelerator-controls-1051.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-service-bulletin-exhaust-manifold-heat-shielding-132.html</guid>
										<title>1973 Corvette: Service Bulletin:  Exhaust Manifold Heat Shielding</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-service-bulletin-exhaust-manifold-heat-shielding-132.html</link>
