<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-corvette-service-bulletin-directional-signal-switch-service-886.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1967-corvette-service-bulletin-keys-for-1967-models-126.html</guid>
										<title>1967 Corvette: Service Bulletin: Keys for 1967 Models</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1967-corvette-service-bulletin-keys-for-1967-models-126.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1967-corvette-service-news-corvette-electric-window-motor-replacement-846.html</guid>
										<title>1967 Corvette: Service News: Corvette Electric Window Motor Replacement</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1967-corvette-service-news-corvette-electric-window-motor-replacement-846.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1967-corvette-electrical-schematic-1967-wiring-diagram-259.html</guid>
										<title>1967 Corvette: Electrical Schematic: 1967 Wiring Diagram</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1967-corvette-electrical-schematic-1967-wiring-diagram-259.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-corvette-engineering-service-letter-muncie-four-speed-transmission-design-change-1072.html</guid>
										<title>1964 Corvette:  Engineering Service Letter:  Muncie Four Speed Transmission Design Change</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-corvette-engineering-service-letter-muncie-four-speed-transmission-design-change-1072.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-1972-corvette-service-news-ignition-pulse-amplifier-sn-c-1-933.html</guid>
										<title>1965 - 1972 Corvette:  Service News:  Ignition Pulse Amplifier (SN-C-1)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1965-1972-corvette-service-news-ignition-pulse-amplifier-sn-c-1-933.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-service-bulletin-audible-noise-in-radio-chevrolet-with-transistorized-ignition-80.html</guid>
										<title>1966 Corvette:  Service Bulletin:  Audible Noise in Radio - Chevrolet with Transistorized Ignition</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1966-corvette-service-bulletin-audible-noise-in-radio-chevrolet-with-transistorized-ignition-80.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1967-corvette-chevrolet-service-news-two-unit-voltage-regulator-diagnosis-and-adjustment-1258.html</guid>
										<title>1963 - 1967 Corvette:  Chevrolet Service News:  Two-Unit Voltage Regulator Diagnosis and Adjustment</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1967-corvette-chevrolet-service-news-two-unit-voltage-regulator-diagnosis-and-adjustment-1258.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1964-1967-corvette-delco-remy-service-bulletin-ignition-systems-940.html</guid>
										<title>1964 - 1967 Corvette:  Delco-Remy Service Bulletin:  Ignition Systems</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-inter-organizationl-letter-high-speed-warning-buzzer-deletion-737.html</guid>
										<title>1963 Corvette: Inter-Organizationl Letter: High-Speed Warning Buzzer Deletion</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-corvette-inter-organizationl-letter-high-speed-warning-buzzer-deletion-737.html</link>
