<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-news-corvette-folding-top-compartment-lid-to-folding-top-interference-sn-68-20-872.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1970-corvette-service-bulletin-1970-corvette-folding-top-material-interference-with-lid-pin-support-980.html</guid>
										<title>1970 Corvette:  Service Bulletin:  1970 Corvette Folding Top Material Interference with Lid Pin Support</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1970-corvette-service-bulletin-1970-corvette-folding-top-material-interference-with-lid-pin-support-980.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-service-bulletin-rear-window-water-leak-1117.html</guid>
										<title>1973 Corvette:  Service Bulletin:  Rear Window Water Leak</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-service-bulletin-rear-window-water-leak-1117.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-recall-product-campaign-no-8005-left-front-fender-skirt-to-brake-pipe-clearance-867.html</guid>
										<title>1968 Corvette: Recall: Product Campaign No. 8005 Left Front Fender Skirt to Brake Pipe Clearance</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-recall-product-campaign-no-8005-left-front-fender-skirt-to-brake-pipe-clearance-867.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1972-corvette-headlight-and-vacuum-line-component-schematic-1165.html</guid>
										<title>1972 Corvette:  Headlight and Vacuum Line Component Schematic</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1972-corvette-headlight-and-vacuum-line-component-schematic-1165.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1970-corvette-service-news-front-fender-side-louver-replacement-1191.html</guid>
										<title>1970 Corvette:  Service News:  Front Fender Side Louver Replacement</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1970-corvette-service-news-front-fender-side-louver-replacement-1191.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-chevrolet-engineering-memo-window-service-update-1227.html</guid>
										<title>1968 Corvette:  Chevrolet Engineering Memo:  Window Service Update</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-chevrolet-engineering-memo-window-service-update-1227.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1978-corvette-service-bulletin-removable-roof-panel-fit-972.html</guid>
										<title>1978 Corvette:  Service Bulletin:  Removable Roof Panel Fit</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1978-corvette-service-bulletin-removable-roof-panel-fit-972.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-lubrication-of-window-regulator-shaft-719.html</guid>
										<title>1968 Corvette: Service Bulletin: Lubrication of Window Regulator Shaft</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-lubrication-of-window-regulator-shaft-719.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-corvette-seattle-zone-letter-1969-door-trim-identification-labels-926.html</guid>
										<title>1969 Corvette:  Seattle Zone Letter:  1969 Door Trim Identification Labels</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-corvette-seattle-zone-letter-1969-door-trim-identification-labels-926.html</link>
