<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-how-to-install-a-bg-speed-demon-basic-87.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-timing-and-vacuum-advance-101-253.html</guid>
										<title>Technical Article:  Timing and Vacuum Advance 101</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-timing-and-vacuum-advance-101-253.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/press-release-batteries-101-how-lead-acid-batteries-work-289.html</guid>
										<title>Press Release: Batteries 101--How Lead-Acid Batteries Work</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/press-release-batteries-101-how-lead-acid-batteries-work-289.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/product-review-best-all-round-we-test-the-goodyear-f1-gs-d3-279.html</guid>
										<title>Product Review:  Best All-Round:  We Test the Goodyear F1 GS-D3</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/product-review-best-all-round-we-test-the-goodyear-f1-gs-d3-279.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/head-casting-numbers-chevrolet-small-block-engines-286.html</guid>
										<title>Head Casting Numbers: Chevrolet Small Block Engines</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/head-casting-numbers-chevrolet-small-block-engines-286.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-synthetic-oil-use-282.html</guid>
										<title>Technical Article:  Synthetic Oil Use</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-synthetic-oil-use-282.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/buying-buying-a-corvette-and-what-to-look-for-293.html</guid>
										<title>Buying: Buying a Corvette and What to Look For</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/buying-buying-a-corvette-and-what-to-look-for-293.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-riveting-experience-home-restorer-s-guide-to-installing-soft-aluminum-rivets-on-your-corvette-245.html</guid>
										<title>Technical Article:  Riveting Experience - Home-Restorer`s Guide to Installing Soft Aluminum Rivets on your Corvette</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-riveting-experience-home-restorer-s-guide-to-installing-soft-aluminum-rivets-on-your-corvette-245.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/tire-storage-recommendations-298.html</guid>
										<title>Tire Storage Recommendations</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/tire-storage-recommendations-298.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/error-codes-on-gm-radios-explained-290.html</guid>
										<title>Error Codes On GM Radios Explained</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/error-codes-on-gm-radios-explained-290.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-corvette-new-application-test-car-of-the-future-by-dave-mclellan-corvette-chief-engineer-1082.html</guid>
										<title>Technical Article:  Corvette - New Application Test Car of the Future - by Dave McLellan - Corvette Chief Engineer</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-corvette-new-application-test-car-of-the-future-by-dave-mclellan-corvette-chief-engineer-1082.html</link>
