<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-1998-corvette-service-news-automatic-transmission-operation-868.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2004-corvette-t-56-borg-warner-transmission-repair-manual-1201.html</guid>
										<title>1997 - 2004 Corvette:  T-56 Borg Warner Transmission Repair Manual</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2004-corvette-t-56-borg-warner-transmission-repair-manual-1201.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-2003-corvette-service-bulletin-info-diagnosis-of-cracked-or-broken-transmission-case-439.html</guid>
										<title>1990 - 2003 Corvette: Service Bulletin: Info - Diagnosis of Cracked or Broken Transmission Case</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-2003-corvette-service-bulletin-info-diagnosis-of-cracked-or-broken-transmission-case-439.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2002-corvette-service-bulletin-automatic-transmission-service-procedure-changes-436.html</guid>
										<title>1997 - 2002 Corvette: Service Bulletin: Automatic Transmission Service Procedure Changes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2002-corvette-service-bulletin-automatic-transmission-service-procedure-changes-436.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2000-2006-corvette-service-bulletin-diagnostic-information-on-diagnostic-trouble-code-dtc-p0894-and-p1870-215.html</guid>
										<title>2000 - 2006 Corvette: Service Bulletin: Diagnostic Information on Diagnostic Trouble Code (DTC) P0894 and P1870</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2000-2006-corvette-service-bulletin-diagnostic-information-on-diagnostic-trouble-code-dtc-p0894-and-p1870-215.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-1999-corvette-service-bulletin-tech-service-engine-soon-ses-light-illuminates-repl-switch-assy-434.html</guid>
										<title>1998 - 1999 Corvette: Service Bulletin: Tech - Service Engine Soon (SES) Light Illuminates (Repl Switch Assy)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1998-1999-corvette-service-bulletin-tech-service-engine-soon-ses-light-illuminates-repl-switch-assy-434.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2001-corvette-service-bulletin-park-neutral-position-switch-connector-cannot-be-removed-437.html</guid>
										<title>1997 - 2001 Corvette: Service Bulletin: Park/Neutral Position Switch Connector Cannot Be Removed</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2001-corvette-service-bulletin-park-neutral-position-switch-connector-cannot-be-removed-437.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2002-corvette-gm-techlink-hydraulic-clutch-fluid-discoloration-97.html</guid>
										<title>1997 - 2002 Corvette: GM TechLink: Hydraulic Clutch Fluid Discoloration</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1997-2002-corvette-gm-techlink-hydraulic-clutch-fluid-discoloration-97.html</link>
