<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1969-1970-corvette-service-bulletin-voltage-regulator-failures-in-the-1970-integrated-delcotrons-865.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1978-1979-corvette-service-bulletin-power-antenna-operation-124.html</guid>
										<title>1978 - 1979 Corvette: Service Bulletin: Power Antenna Operation</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1978-1979-corvette-service-bulletin-power-antenna-operation-124.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1977-corvette-service-bulletin-anti-theft-alarm-switch-protective-grease-1104.html</guid>
										<title>1977 Corvette:  Service Bulletin:  Anti-Theft Alarm Switch - Protective Grease</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1977-corvette-service-bulletin-anti-theft-alarm-switch-protective-grease-1104.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1979-1982-corvette-service-bulletin-no-am-reception-with-replacement-power-antenna-mast-1215.html</guid>
										<title>1979 - 1982 Corvette:  Service Bulletin:  No AM Reception with Replacement Power Antenna Mast</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1979-1982-corvette-service-bulletin-no-am-reception-with-replacement-power-antenna-mast-1215.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-electrical-schematic-wiper-washer-system-212.html</guid>
										<title>2006 Corvette:  Electrical Schematic: Wiper Washer System</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2006-corvette-electrical-schematic-wiper-washer-system-212.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1978-1980-corvette-service-news-speedometer-system-noise-diagnosis-and-repair-1188.html</guid>
										<title>1978 - 1980 Corvette:  Service News:  Speedometer System Noise Diagnosis and Repair</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1978-1980-corvette-service-news-speedometer-system-noise-diagnosis-and-repair-1188.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1979-corvette-service-news-corvette-auxiliary-cooling-fan-wiring-revision-897.html</guid>
										<title>1979 Corvette:  Service News:  Corvette Auxiliary Cooling Fan Wiring Revision</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1979-corvette-service-news-corvette-auxiliary-cooling-fan-wiring-revision-897.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-electrical-schematic-engine-192.html</guid>
										<title>1973 Corvette:  Electrical Schematic: Engine</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-electrical-schematic-engine-192.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-windshield-wiper-system-operation-and-diagnosis-697.html</guid>
										<title>1968 Corvette: Service Bulletin: Windshield Wiper System - Operation and Diagnosis</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-windshield-wiper-system-operation-and-diagnosis-697.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1979-1984-corvette-service-bulletin-power-antenna-rod-and-cable-service-package-1015.html</guid>
										<title>1979 - 1984 Corvette:  Service Bulletin:  Power Antenna Rod and Cable Service Package</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1979-1984-corvette-service-bulletin-power-antenna-rod-and-cable-service-package-1015.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1981-corvette-service-bulletin-vehicle-speed-sensor-servicing-677.html</guid>
										<title>1981 Corvette: Service Bulletin: Vehicle Speed Sensor Servicing</title>
