<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-1996-corvette-technical-article-how-to-replace-your-front-brakes-86.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-corvette-service-bulletin-brake-pedal-not-fully-returning-stop-lights-stay-on-and-or-roughness-vibration-from-rear-of-vehicle-634.html</guid>
										<title>1992 Corvette: Service Bulletin: Brake Pedal Not Fully Returning / Stop Lights Stay On and/or Roughness/Vibration From Rear of Vehicle</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1992-corvette-service-bulletin-brake-pedal-not-fully-returning-stop-lights-stay-on-and-or-roughness-vibration-from-rear-of-vehicle-634.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-recall-front-brake-caliper-bracket-bolt-644.html</guid>
										<title>1984 Corvette: Recall: Front Brake Caliper Bracket Bolt</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1984-corvette-recall-front-brake-caliper-bracket-bolt-644.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-corvette-service-bulletin-abs-pump-noisy-abs-active-light-flashes-637.html</guid>
										<title>1991 Corvette: Service Bulletin: ABS Pump Noisy / &quot;ABS Active&quot; Light Flashes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1991-corvette-service-bulletin-abs-pump-noisy-abs-active-light-flashes-637.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-recall-inoperative-parking-brake-639.html</guid>
										<title>1990 Corvette: Recall: Inoperative Parking Brake</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1990-corvette-recall-inoperative-parking-brake-639.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1990-corvette-recall-notice-product-campaign-90c09-inoperative-parking-brake-1095.html</guid>
										<title>1989 - 1990 Corvette:  Recall Notice:  Product Campaign 90C09 Inoperative Parking Brake</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1989-1990-corvette-recall-notice-product-campaign-90c09-inoperative-parking-brake-1095.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-1991-corvette-service-bulletin-information-on-abs-noise-self-test-641.html</guid>
										<title>1986 - 1991 Corvette: Service Bulletin: Information on ABS Noise - Self Test</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-1991-corvette-service-bulletin-information-on-abs-noise-self-test-641.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-corvette-recall-notice-anti-skid-brake-system-master-cylinder-center-valve-895.html</guid>
										<title>1986 Corvette:  Recall Notice:  Anti-Skid Brake System Master Cylinder Center Valve</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1986-corvette-recall-notice-anti-skid-brake-system-master-cylinder-center-valve-895.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1996-corvette-visual-differences-between-production-brakes-640.html</guid>
										<title>1988 -1996 Corvette : Visual Differences Between Production Brakes</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1988-1996-corvette-visual-differences-between-production-brakes-640.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1981-1990-corvette-service-bulletin-brake-rotor-refinish-parts-ordering-information-710.html</guid>
										<title>1981 - 1990 Corvette: Service Bulletin: Brake Rotor Refinish Parts Ordering Information</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1981-1990-corvette-service-bulletin-brake-rotor-refinish-parts-ordering-information-710.html</link>
