<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1954-corvette-technical-article-summary-report-on-changes-to-achieve-improvement-in-corvette-handling-and-ride-85.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1962-corvette-frame-specifications-258.html</guid>
										<title>1953 - 1962 Corvette: Frame Specifications</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1953-1962-corvette-frame-specifications-258.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-corvette-service-bulletin-excessive-driveline-vibration-941.html</guid>
										<title>1959 Corvette:  Service Bulletin:  Excessive Driveline Vibration</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-corvette-service-bulletin-excessive-driveline-vibration-941.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-corvette-service-news-drive-line-vibration-corvette-51.html</guid>
										<title>1959 Corvette:  Service News:  Drive Line Vibration - Corvette</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-corvette-service-news-drive-line-vibration-corvette-51.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-1961-corvette-service-bulletin-front-and-rear-coil-spring-heights-785.html</guid>
										<title>1959 - 1961 Corvette: Service Bulletin: Front and Rear Coil Spring Heights</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-1961-corvette-service-bulletin-front-and-rear-coil-spring-heights-785.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-corvette-service-bulletin-instability-above-60-mph-962.html</guid>
										<title>1956 Corvette:  Service Bulletin:  Instability  Above 60 MPH</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1956-corvette-service-bulletin-instability-above-60-mph-962.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-1960-corvette-zone-letter-steering-gear-lube-leaking-from-directional-signal-housing-792.html</guid>
										<title>1959 - 1960 Corvette: Zone Letter: Steering Gear Lube Leaking From Directional Signal Housing</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1959-1960-corvette-zone-letter-steering-gear-lube-leaking-from-directional-signal-housing-792.html</link>
