<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-service-bulletin-13417-service-update-for-inventory-and-customer-vehicles-engine-protection-mode-activated-during-aggressive-driving-848.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-corvette-service-update-performance-timer-missing-1262.html</guid>
										<title>2016 Corvette:  Service Update - Performance Timer Missing</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2016-corvette-service-bulletin-diagnostic-tip-for-malfunction-indicator-light-mil-illuminated-dtc-p0420-and-p0430-set-1277.html</guid>
										<title>2014 - 2016 Corvette:  Service Bulletin: Diagnostic Tip for Malfunction Indicator Light (MIL) Illuminated, DTC P0420 and P0430 Set</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2016-corvette-service-bulletin-diagnostic-tip-for-malfunction-indicator-light-mil-illuminated-dtc-p0420-and-p0430-set-1277.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-service-bulletin-pi1410a-normal-characteristic-instrument-panel-red-brake-light-intermittently-comes-on-1358.html</guid>
										<title>2014 - 2015 Corvette: Service Bulletin: #PI1410A: Normal Characteristic - Instrument Panel Red Brake Light Intermittently Comes On</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-service-bulletin-pi1410a-normal-characteristic-instrument-panel-red-brake-light-intermittently-comes-on-1358.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2016-corvette-service-bulletin-16-na-188-loss-of-radio-controls-and-or-hvac-controls-jun-29-2016-1287.html</guid>
										<title>2014 - 2016 Corvette:  Service Bulletin:  #16-NA-188: Loss of Radio Controls and/or HVAC Controls - (Jun 29, 2016)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2016-corvette-service-bulletin-16-na-188-loss-of-radio-controls-and-or-hvac-controls-jun-29-2016-1287.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2018-2019-corvette-gm-techlink-intermittent-parasitic-battery-draw-below-40°-f-4°-c-1423.html</guid>
										<title>2018 - 2019 Corvette: GM TechLink: Intermittent Parasitic Battery Draw Below 40° F/4° C</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2018-2019-corvette-gm-techlink-intermittent-parasitic-battery-draw-below-40°-f-4°-c-1423.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-corvette-service-bulletin-navigation-radio-destination-state-defaults-to-wv-instead-of-va-on-manual-entry-only-1307.html</guid>
										<title>2016 Corvette:  Service Bulletin: Navigation Radio Destination State Defaults To WV Instead of VA On Manual Entry Only</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-corvette-service-bulletin-navigation-radio-destination-state-defaults-to-wv-instead-of-va-on-manual-entry-only-1307.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-2017-corvette-convertible-customer-satisfaction-program-17245-mechanical-trunk-release-may-not-operate-1371.html</guid>
										<title>2016 - 2017 Corvette Convertible: Customer Satisfaction Program: 17245  Mechanical  Trunk Release May Not Operate</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2016-2017-corvette-convertible-customer-satisfaction-program-17245-mechanical-trunk-release-may-not-operate-1371.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-gm-techlink-compass-always-shows-north-1259.html</guid>
										<title>2014 Corvette:  GM TechLink:  Compass Always Shows North</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-gm-techlink-compass-always-shows-north-1259.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-gm-techlink-aftermarket-equipment-connected-to-multi-media-auxiliary-ports-during-diagnosis-1186.html</guid>
										<title>2014 - 2015 Corvette:  GM TechLink:  Aftermarket Equipment Connected to Multi-Media/Auxiliary Ports during Diagnosis</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2015-corvette-gm-techlink-aftermarket-equipment-connected-to-multi-media-auxiliary-ports-during-diagnosis-1186.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2016-corvette-service-bulletin-pic6193b-cannot-save-xm-favorites-1308.html</guid>
										<title>2014 - 2016 Corvette:  Service Bulletin: PIC6193B: Cannot Save XM Favorites</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-2016-corvette-service-bulletin-pic6193b-cannot-save-xm-favorites-1308.html</link>
