<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2014-corvette-recall-low-rear-differential-fluid-level-847.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2017-corvette-service-bulletin-16-na-404-harsh-shift-delayed-shift-unwanted-downshift-transmission-stuck-in-one-gear-erratic-shifting-hesitation-or-have-a-malfunction-indicator-lamp-mil-illuminated-1353.html</guid>
										<title>2017 Corvette:  Service Bulletin:  #16-NA-404: Harsh Shift, Delayed Shift, unwanted Downshift, Transmission Stuck in One Gear, Erratic Shifting, Hesitation or Have a Malfunction Indicator Lamp (MIL) Illuminated</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2017-corvette-service-bulletin-16-na-404-harsh-shift-delayed-shift-unwanted-downshift-transmission-stuck-in-one-gear-erratic-shifting-hesitation-or-have-a-malfunction-indicator-lamp-mil-illuminated-1353.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2017-corvette-service-bulletin-16-na-364-delayed-engagement-after-sitting-with-engine-off-clutch-slow-to-fill-1373.html</guid>
										<title>2015 - 2017 Corvette: Service Bulletin: #16-NA-364: Delayed Engagement After Sitting With Engine Off - Clutch Slow to Fill</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2019-corvette-service-bulletin-18-na-285-information-on-slight-movement-in-park-at-ignition-on-and-vehicle-start-up-and-or-during-a-remote-vehicle-start-event-jan-22-2021-1486.html</guid>
										<title>2015 - 2019 Corvette: Service Bulletin: #18-NA-285: Information on Slight Movement in Park at Ignition On and Vehicle Start Up and/or During a Remote Vehicle Start Event - (Jan 22, 2021)</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2019-corvette-service-bulletin-18-na-285-information-on-slight-movement-in-park-at-ignition-on-and-vehicle-start-up-and-or-during-a-remote-vehicle-start-event-jan-22-2021-1486.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2017-corvette-service-bulletin-pip5437b-8l45-8l90-diagnostic-tips-for-harsh-shifts-and-delayed-or-harsh-garage-shift-engagements-1365.html</guid>
										<title>2015 - 2017 Corvette: Service Bulletin: #PIP5437B: 8L45 8L90 Diagnostic Tips for Harsh Shifts and Delayed or Harsh Garage Shift Engagements</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-2017-corvette-service-bulletin-pip5437b-8l45-8l90-diagnostic-tips-for-harsh-shifts-and-delayed-or-harsh-garage-shift-engagements-1365.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-corvette-gm-press-release-new-8-speed-enables-quicker-more-efficient-corvette-869.html</guid>
										<title>2015 Corvette:  GM Press Release:  New 8-Speed Enables Quicker, More Efficient Corvette</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-corvette-gm-press-release-new-8-speed-enables-quicker-more-efficient-corvette-869.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/c7-corvette-service-information-transmission-control-lever-knob-replacement-1294.html</guid>
										<title>C7 Corvette:  Service Information:  Transmission Control Lever Knob Replacement</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/c7-corvette-service-information-transmission-control-lever-knob-replacement-1294.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-corvette-gm-techlink-reprogramming-procedures-for-the-8l90-8-speed-transmission-1198.html</guid>
										<title>2015 Corvette:  GM TechLink:  Reprogramming Procedures for the 8L90 8-Speed Transmission</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/2015-corvette-gm-techlink-reprogramming-procedures-for-the-8l90-8-speed-transmission-1198.html</link>
