<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-corvette-service-news-fuel-injection-diagnosis-chart-revision-844.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1970-1973-corvette-service-bulletin-engine-overheat-1220.html</guid>
										<title>1970 - 1973 Corvette:  Service Bulletin:  Engine Overheat</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1970-1973-corvette-service-bulletin-engine-overheat-1220.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-leakage-at-oil-filter-1081.html</guid>
										<title>1968 Corvette Service Bulletin:  Leakage at Oil Filter</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-leakage-at-oil-filter-1081.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-1974-corvette-service-bulletin-engine-overheat-due-to-blocked-coolant-passage-in-the-cylinder-head-1115.html</guid>
										<title>1973 - 1974 Corvette:  Service Bulletin:  Engine Overheat Due to Blocked Coolant Passage in the Cylinder Head</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-1974-corvette-service-bulletin-engine-overheat-due-to-blocked-coolant-passage-in-the-cylinder-head-1115.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-service-bulletin-exhaust-manifold-heat-shielding-132.html</guid>
										<title>1973 Corvette: Service Bulletin:  Exhaust Manifold Heat Shielding</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-service-bulletin-exhaust-manifold-heat-shielding-132.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-engineering-service-letter-upper-radiator-hose-alignment-25.html</guid>
										<title>1968 Corvette:  Engineering Service Letter:  Upper Radiator Hose Alignment</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-engineering-service-letter-upper-radiator-hose-alignment-25.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1970-corvette-service-news-1970-carburetor-linkage-and-accelerator-controls-1051.html</guid>
										<title>1970 Corvette:  Service News:  1970 Carburetor Linkage and Accelerator Controls</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1970-corvette-service-news-1970-carburetor-linkage-and-accelerator-controls-1051.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-1969-corvette-engineering-service-letter-heat-shield-starting-motor-solenoid-907.html</guid>
										<title>1968 - 1969 Corvette:  Engineering Service Letter:  Heat Shield - Starting Motor Solenoid</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-1969-corvette-engineering-service-letter-heat-shield-starting-motor-solenoid-907.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-news-spark-plug-removal-with-427-engine-and-a-c-680.html</guid>
										<title>1968 Corvette: Service News: Spark Plug Removal with 427 Engine and A/C</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-news-spark-plug-removal-with-427-engine-and-a-c-680.html</link>
