<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1972-1973-corvette-service-news-new-vacuum-modulator-hoses-839.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-electrical-schematic-engine-192.html</guid>
										<title>1973 Corvette:  Electrical Schematic: Engine</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-electrical-schematic-engine-192.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-corvette-service-news-fuel-injection-diagnosis-chart-revision-844.html</guid>
										<title>1982 Corvette: Service News: Fuel injection Diagnosis Chart Revision</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-corvette-service-news-fuel-injection-diagnosis-chart-revision-844.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-leakage-at-oil-filter-1081.html</guid>
										<title>1968 Corvette Service Bulletin:  Leakage at Oil Filter</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-leakage-at-oil-filter-1081.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-service-bulletin-exhaust-manifold-heat-shielding-132.html</guid>
										<title>1973 Corvette: Service Bulletin:  Exhaust Manifold Heat Shielding</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-service-bulletin-exhaust-manifold-heat-shielding-132.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-corvette-service-bulletin-engine-coolant-usage-anti-freeze-specs-change-675.html</guid>
										<title>1982 Corvette: Service Bulletin: Engine Coolant Usage Anti-Freeze Specs Change</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-corvette-service-bulletin-engine-coolant-usage-anti-freeze-specs-change-675.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-cold-start-failure-1063.html</guid>
										<title>1968 Corvette:  Service Bulletin:  Cold Start Failure</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-cold-start-failure-1063.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-choke-and-hot-restart-problems-930.html</guid>
										<title>1968 Corvette:  Service Bulletin:  Choke and Hot Restart Problems</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-service-bulletin-choke-and-hot-restart-problems-930.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1974-corvette-service-bulletin-soft-push-rod-guides-837.html</guid>
										<title>1974 Corvette: Service Bulletin: Soft Push Rod Guides</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1974-corvette-service-bulletin-soft-push-rod-guides-837.html</link>
