<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1974-corvette-service-bulletin-soft-push-rod-guides-837.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1982-corvette-service-bulletin-cooling-system-restrictions-symptoms-and-diagnosis-1131.html</guid>
										<title>1963 - 1982 Corvette:  Service Bulletin:  Cooling System Restrictions - Symptoms and Diagnosis</title>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-corvette-service-bulletin-engine-coolant-usage-anti-freeze-specs-change-675.html</guid>
										<title>1982 Corvette: Service Bulletin: Engine Coolant Usage Anti-Freeze Specs Change</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-corvette-service-bulletin-engine-coolant-usage-anti-freeze-specs-change-675.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1982-corvette-technical-article-knowing-how-your-1963-1982-corvette-s-cooling-system-can-prevent-a-steaming-summer-241.html</guid>
										<title>1963 - 1982 Corvette: Technical Article: Knowing How Your 1963 - 1982 Corvette`s Cooling System Can Prevent a Steaming Summer</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1963-1982-corvette-technical-article-knowing-how-your-1963-1982-corvette-s-cooling-system-can-prevent-a-steaming-summer-241.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1975-corvette-service-news-radiator-and-fan-shroud-removal-1046.html</guid>
										<title>1975 Corvette:  Service News:  Radiator and Fan Shroud Removal</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1975-corvette-service-news-radiator-and-fan-shroud-removal-1046.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-engineering-service-letter-incorrect-camshafts-in-production-at-flint-engine-plant-1107.html</guid>
										<title>1968 Corvette:  Engineering Service Letter:  Incorrect Camshafts in Production at Flint Engine Plant</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1968-corvette-engineering-service-letter-incorrect-camshafts-in-production-at-flint-engine-plant-1107.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1971-corvette-service-bulletin-1971-corvette-axle-usage-corrections-1054.html</guid>
										<title>1971 Corvette:  Service Bulletin:  1971 Corvette Axle Usage Corrections</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1971-corvette-service-bulletin-1971-corvette-axle-usage-corrections-1054.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-corvette-service-news-fuel-filter-usage-and-installation-938.html</guid>
										<title>1982 Corvette:  Service News:  Fuel Filter Usage and Installation</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1982-corvette-service-news-fuel-filter-usage-and-installation-938.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-electrical-schematic-engine-192.html</guid>
										<title>1973 Corvette:  Electrical Schematic: Engine</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/1973-corvette-electrical-schematic-engine-192.html</link>
