										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-how-to-repair-rebuild-your-alternator-90.html</guid>
										<title>Technical Article: How to Repair &amp; Rebuild your Alternator</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-how-to-repair-rebuild-your-alternator-90.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-advantages-of-an-oil-prime-tool-251.html</guid>
										<title>Technical Article:  Advantages of an Oil Prime Tool</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-advantages-of-an-oil-prime-tool-251.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/service-bulletin-cleaning-coating-and-painting-of-aluminum-wheels-278.html</guid>
										<title>Service Bulletin: Cleaning, Coating and Painting of Aluminum Wheels</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/service-bulletin-cleaning-coating-and-painting-of-aluminum-wheels-278.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-mapping-your-advance-curve-252.html</guid>
										<title>Technical Article:  Mapping Your Advance Curve</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/technical-article-mapping-your-advance-curve-252.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/service-bulletin-fluid-leak-detection-294.html</guid>
										<title>Service Bulletin: Fluid Leak Detection</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/service-bulletin-fluid-leak-detection-294.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/small-block-and-big-block-engine-bore-and-stroke-chart-283.html</guid>
										<title>Small Block and Big Block Engine Bore and Stroke Chart</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/small-block-and-big-block-engine-bore-and-stroke-chart-283.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/head-casting-numbers-chevrolet-small-block-engines-286.html</guid>
										<title>Head Casting Numbers: Chevrolet Small Block Engines</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/head-casting-numbers-chevrolet-small-block-engines-286.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/paint-orange-peel-as-it-applies-to-corvette-paint-quality-296.html</guid>
										<title>Paint: Orange Peel as it Applies to Corvette Paint Quality</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/paint-orange-peel-as-it-applies-to-corvette-paint-quality-296.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/determining-the-resistance-value-of-the-ignition-key-resistor-pellet-291.html</guid>
										<title>Determining the Resistance Value of the Ignition Key Resistor Pellet</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/determining-the-resistance-value-of-the-ignition-key-resistor-pellet-291.html</link>
										<guid>https://www.corvetteactioncenter.com/tech/knowledgebase/article/product-evaluation-3m-scotchcal-car-bra-300.html</guid>
										<title>Product Evaluation: 3M Scotchcal Car Bra</title>
										<link>https://www.corvetteactioncenter.com/tech/knowledgebase/article/product-evaluation-3m-scotchcal-car-bra-300.html</link>
